Well, that really depends upon how you are "networked". Obviously, the primary PC is USB 2.0 connected direct to the printer. When you send a print job, the PC merely starts the print job and sends it to the printer on the fly. The other PC must first spool the entire job, packet it up, send it to the network, then network sends it to the first PC, where it must unpacket it, and send it to the printer. This is definitely going to be slower than a direct connection. And if your network connections are wireless rather than wired, even longer.
SOURCE: HP Laser Jet 2840
try to recalibrate the cartridge carousel. the central axel is twisted. there are more than 2 problems like this arownd...
SOURCE: laser jet 2430tn printing slow
Check the way your print Jobs Spool up in your PC. you may have a totally different set up for printing in your new computer that takes two or three extra steps(such as spooling the print job) prior to actually sending it to the printer to be printed. If you have a user manual for your new computer, check the printer set up and see if it is set up to print directly to printer or print to spooling folder then to printer. Also try a different driver if you wish, I know the 2430 can use either PCL5 or PCL6 drivers... I'd start there and see if there is a difference.... the problem isn't your printer obviously its the way your computer is communicating to it. Best of luck to you.
Faxgenius.
SOURCE: Printer is printing black lines across all print jobs
i would check the fixing section of the machine which is the hottest part of the machine. weather it is a film or roller you probley have a mark that unit
SOURCE: HP P1005 PRINT JOB SITS IN QUE, WO'T PRINT
Does it show "Printing" or "Spooling" in the job queue window?
Open the Job queue window, then highlight and cancel the print job. Send a small print job to the printer and make sure that the PC and the printer are communicating.
If the failure re-occurs, then clear the queue again and close it and restart i=the queue.
Don
Testimonial: "Thank you for your response, Even after I asked if every cord was plugged, I did'nt check myself. The usb cable was unplugged ! Agh !!!!!"
SOURCE: Samsung ML-2525W monochrome laser printer;
I have the same problem with mine - first job usually prints but no go on the second one. It tells me the printer is "offline". In some cases I can't even power cycle normally. I have to unplug the back cord and plug it back in, then I can power back on.
I called Samsung today 1-800-726-7864 and was told the printer will need to be taken to a repair center for service.
Wish I had better news.
