SOURCE: fisher and paykel gw509 not draining, pump is clear
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
SOURCE: fisher and paykel intuitive washing machine not spinning
to remove the pump - remove power pins. Press bayonet clip in [lhs of pump base. Twist anti clockwise. Remove blockage. Rub a smear of Vaseline on seal before re assembly
SOURCE: fisher and paykel washing machine will not spin
Most likely something stuck in the pump, you need to look underneath to get to it, the pump turns anti clockwise to remove it.
SOURCE: Fisher and Paykel intuitive eco - I have too many suds -tried all
This may sound silly but have you checked your washing powder? Here in Australia (not sure where you are) most detergent manufactures are concentrating their powdered detergents but haven't made much fuss on the packaging - just giving you smaller scoops.
I hope for your sake it is something as simple as that.
