LG 22" FLATRON LCD Monitor Logo
m
manish Posted on Feb 21, 2016
Dear sir my lg 22" flatron w2243t lcd is on but no picture come but red light is on
Manish parmar mob:-9413465091
5 Related Answers
Rommel Balcita
  • 749 Answers
  • Posted on Nov 27, 2007
SOURCE: LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
ginko
Ginko
  • 19396 Answers
  • Posted on Apr 22, 2009
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Anonymous
  • 21 Answers
  • Posted on May 24, 2009
SOURCE: I have a LG Flatron 22", LCD monitor, model is W22345. dilemma: after sleeping the computer for the night, as I have been doing for the past 8 months that the computer and monitor has been in my owne
Check the video cable,replace them, and if didnt work, try to reset the config stored on the settings of the monitor (usually by menu).
Some electronic problems could do the same simptom. check the manual for hints.
Good luck
Anonymous
  • Posted on May 29, 2009
SOURCE: No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
Anonymous
  • 173 Answers
  • Posted on Jun 13, 2009
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
1helpful
My lg monitor screen is black. It powers on but no picture or light. What could be wrong?
Several things, it could just be turned down real low but most likely it is not getting a signal from the source. What color is the light on the bottom. If it is not green you have an input signal problem.
1helpful
How to open lg lcd flatron L1552S
help what open monitor flatron l1552s ? for fix
My LG FLatron W1942T Monitor shows the picture half light half dark. CAN ANYONE HELP ME TO SOLVE THE PROBLEM?
Hello
There seems to be a problem with the inverter PCB responsible in glowing the required lamp. Hence try to check if any physical damage to the lamp if not then you may have to go for power supply
I cant see the red color on my lg LCD (flatron l1919s). instead there is like a blue light in the screen (all the pictures and faces are blue, and red events are black).
Failing internal components (but first before sending in for repair, check the computer graphics card is ok, as this, or the VGA cable to monitor may be suspect)
In effect what is happening is that the hardware that controls the spread of green and red pixels on the screen has failed (happens over time), this will need repair or more likely replacement
1helpful
4answers
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
Screen just goes all white then red,green,and blue color flashing
Is it that the screen just went blank or white without any display? need more clarification, but If it is, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
9helpful
Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
30helpful
My LG flatron golden eye tv got Child Locked -
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Good luck
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
