2001 Dodge Stratus Logo
Matthew Smith Posted on Feb 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the code p0139. replaced o2 twice, need to track down the wiring. does anyone have some advice? my cat fell off and that is what damaged the 02/wireing. Se 4 door motel 2.4 dohc 149cl
Jeff Armer
Level 3:
  • Dodge Master 15,575 Answers
  • Posted on Feb 21, 2016
Jeff Armer
Dodge Master
Level 3:
Answers
15575
Questions
Helped
7111380
Points
73899
Go to http://bbbind.com/free_tsb.html free wiring diagrams .
Testimonial: "thanks but cant find a one for the o2 in there."
  • Jeff Armer Feb 21, 2016
    You need to go to engine under system , then subsystem fuel controls > first blue link ,click on that 5 pages down . top of that page cam an crank sensors wiring ,bottom O2 sensors .
2helpful
2007 ford escape V6, replaced sensor forP0141 code persists, need diagram for the 02 sensor harness to PCM to check damaged wires had a alternator replaced before i purchased it, maybe a wire got cut
No code tells you to replace a part , need to do diagnostic's for said code .
P0141 - O2 Heater Circuit (Bank 1, Sensor 2) Description: See the description for DTC P0135. Possible Causes: See the possible causes for DTC P0135. Diagnostic Aids: See the diagnostic aids for DTC P0135. Application Key On Engine Off Key On Engine Running Continuous Memory All GO to Pinpoint Test DW .
DW: Heated Oxygen Sensor (HO2S) DW: Introduction DW1 CHECK FOR DIAGNOSTIC TROUBLE CODES (DTCS) Are DTCs P0040, P0041, P0053, P0054, P0055, P0059, P0060, P0132, P0133, P0135, P0138, P0139, P0141, P0144, P0147, P0152, P0153, P0155, P0158, P0159, P0161, or P1127 present?
Yes No For DTCs P0040 or P0041, GO to DW2 .
For DTCs P0053, P0054, P0055, P0059 or P0060, GO to DW14 .
For DTCs P0132, P0138, P0144, P0152 or P0158, GO to DW20 .
For DTCs P0133 or P0153, GO to DW3 .
For DTCs P0135, P0139, P0141, P0147, P0155, P0159 or P0161, GO to DW9 .
For DTC P1127, GO to DW19 . For all others, GO to Section 4, Diagnostic Trouble Code (DTC) Charts and Descriptions .
DW9 DTCS P0135, P0139, P0141, P0147, P0155, P0159 OR P0161: CHECK FOR A SOURCE OF POTENTIAL HO2S CONTAMINATION
  • Investigate the following items as potential sources of HO2S contamination:
    • use of unapproved silicon sealers
    • fuel contaminated by silicon additives
    • excessive oil consumption
    • glycol leaking internally in the engine
    • lead-contaminated fuel
    • short drive cycles in cold weather
    • use of unapproved cleaning agents
Is a concern present?
Yes No REPAIR the source of the contamination.
CHANGE the engine oil and oil filter.
RESET the keep alive memory (KAM). REFER to Section 2, Resetting The Keep Alive Memory (KAM) .
REPEAT the self-test. GO to DW10 .
1helpful
code p 0139 refers to heated oxygen sensor (HO2S) 2 bank 1--slow response===causes --heating inoperative--wiring--HO2S
or
oxygen sensor(O2) 2 bank 1---slow response===causes--wiring ---O2 sensor
as you have replaced the O2 sensor twice with no results then it will be the heated sensor that is faulty
heated sensors are the units in the exhaust manifold of exhaust pipe before the cat converter and O2 sensors are the units after the cat converter
It is normally the HO2 sensor that fails and the wiring problem is from not using the correct special socket for installation or removal that causes damage to the fragile wires to the unit
3answers
PO-139 I had that sensor change 3 weeks ago and the check engine light came on again this morning.Thanks
Probably replaced a good sensor. This codes could be from a bad sensor, a vacuum leak, or an exhaust leak before the sensor.
2answers
The engine stalls. A P0139 code is stored. What's wrong?
Causes
A code P0139 may mean that one or more of the following has happened: The oxygen sensor is faulty The wiring to the sensor is broken / frayed There is an exhaust leak
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back.
If the code comes back, the problem is more than likely the rear driver's side oxygen sensor. You will likely wind up replacing it but you should also consider these possible solutions:
Check and fix any exhaust leaks
Check for wiring problems (shorted, frayed wires)
Check the frequency and amplitude of the oxygen sensor (advanced)
Check for a deteriorating / contaminated oxygen sensor, replace if necessary Check for inlet air leaks
Check the MAF sensor for proper operation
Code p0057 will not go away
main problem that you have not addressed with the o2 sensor is the fact that the wires have been damaged and that there is a dead short to ground. Probably the wires are severely twisted and a wire has broken and touching the earth wire or the metal body of the sensor.
I have a 2002 Chevy Express 1500. I have a engine code of p0420. I have changed all of my o2 sensors , gas cap , mass air sensor & the cat twice. Dose anyone know what's the deal with this????
Ok i see you replaced your cats Now the question is did you use oem parts ?? Cause that can make all the difference! And do you have dual cats if so did you replace the one twice or both ?? Also check your ground wire for corrosion or a loose connection this ground can be found either on the right front of the engine or the rear of the engine. one more thing just make sure there are no leaks before the converters. Good luck
1helpful
2003 cavalier ls 2.2L show engine code p0141, O2 sensor replaced, no problems found in the wiring. Now what?
2003 cavaleir with code po141. this codes is saying o2 heater , so yes if sensor wiring is good then o2 is bad, but which o2 did you change? the correct o2 is the rear one after the converter not before the coverter, theres one up by the engine and i think its on the exhaust manifold and then another o2 down on the exhaust after the cat, thats the one you need to replace, let me know is thats the one, if not and you replaced the one at engine then replace the other one after the cat and this will solve the problem, let me know hope this is helpful.johnjohn2_12.jpg
2answers
I'm getting 3 codes on my Audi A6 po118 Coolant temp circuit high input po421 bank one warm up catalyst below thresh hold and po431 bank two warm up catalyst below thresh hold.
I have about 15 years experience with Audi/VW. The coolant issue is more like the result of the ECM coolant temp sensor failure. The Cat code might be the front oxygen sensor on that bank and not the front cat. If you need more information about this repair please fell free to contact me at [email protected], I have over 30 years of automotive experience to assist you, thanks.
3helpful
My car indicates check engine sigh with following two codes 1: p0139 2: p0140
Hi Garcha,
Both codes relate to O2 Sensor # 2
Code P0139: O2 Sensor Circuit Slow Response - Bank 1, Sensor 2
Code P0140: O2 Sensor Circuit No Activity Detected - Bank 1, Sensor 2
A faulty O2 sensor will mean incorrect signals will be sent to the EFI computer, causing erratic engine running.
Cheers,
"If this has helped you in any way, please rate this solution" :-)
4helpful
2answers
P0139 code for a 2003 hyundai elantra. What is this code?
Hi the code P0139 is Bank 1 sensor 2 lambda sensor fault ,possible wiring or sensor fault even if you replace the sensor you need to have the MIL lamp turned off by a Diagnostic machine,it is possible you have another fault such as poor Catalytic converter efficency giving the same fault code ,Would recomend you get the car checked and read the "live" data as the car see`s it to make an accurate diagnosis and cure
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
