Replaced on HES on Saturday morning, washed all day Saturday and Sunday, now this morning getting the LE code again.
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed
when either the motor is not working or the control board thinks that the motor
is locked up. A Hall Effect sensor is used in these washers which monitors the
speed and direction of the motor and then forwards this information to the
control board. Hope you understand by now that this LE error is displayed when there
is an issue with the motor or when the Hall Effect sensor sends wrong signal to
the control. Conclusion is you'll have to check both motor and hall sensor and
replace the part# that is bad, usually I have seen the sensor going bad. Please
get back to me if you have any other questions.
Kevin
Kevin
Kevin
Hello &
Welcome to FixYa
is locked up. A Hall effect sensor is used in these washer which monitors the
their is an issue with the motor or when the hall effect sensor sends wrong
signal to the control. Conclusion is you'll have to check both motor and hall
sesor and replace the part# that is bad, usually I have seen the sensor going
bad. Please get back to me if you have any other questions.
Kevin
