Optics Logo
A
Anonymous Posted on Feb 22, 2016
Finding model number on tasco trail camera
I have a tasco trail camera, I received as a gift. The packaging and instruction manual was disposed of and I'm at a loss because the other manuals call for a usb port and I have seen that have eight batteries that mine has. Can you help?
Thomas Stromgren
Level 2:
Social Butterfly:
An expert who has shared 10 answers on their Facebook wall.
  • Expert 166 Answers
  • Posted on Apr 22, 2016
Thomas Stromgren
Expert
Level 2:
Social Butterfly:
Answers
166
Questions
Helped
114809
Points
537
Hi!...
You can get the manual for this type of Tasco Trail Camera here:
Instruction Manuals Tasco Believe it
I hope this helps you!
5 Related Answers
informatica
Greg Cann
  • 1114 Answers
  • Posted on Sep 07, 2008
SOURCE: Tasco Manual
Hi - You can download the manual by clicking the link underlined in blue below:
46-114500
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Anonymous
  • 7 Answers
  • Posted on Oct 15, 2008
SOURCE: Instruction Manual
I have the both of the original instruction manuals. i can scan it if you'd like.
Joe L
Joe Lalumia aka TelescopeMan
  • 3186 Answers
  • Posted on May 18, 2009
SOURCE: trying to identify older tasco telescope and put it together
There are only two types of telescopes --- REFRACTORS, and REFLECTORS-
The refractor has a lens on the front of the tube and you insert different eyepieces in the back-- the larger the number written on the eyepiece the LOWER the magnification-- (DO NOT USE THE 2x or 3x barlow which you may have!-- this creates too much power for this small telescope!-- put it away and never use it!)
A reflector has a main mirror on the bottom of the tube, and a small secondary mirror under the eyepiece hole (focuser end) - front end-- put the lowest power eyepiece into the focuser.
Now with either type telescope go out side during the day and practice focusing on a distant object-- turn the knob SLOWLY. At night the moon should be the first target you try.
If you received what appears to be a smaller telescope -- that is the finder scope-- attach it to the top of the tube on the main telescope. Again during the day line up the small finder scope with the main scope-- look at a distant telephone pole (the very top-- and center this in the main telescope. Without moving the main scope use the finder scopes "screws" to adjust the cross hairs so they are pointing exactly where the main scope is pointed. Now you can use the small finder scope to point the telescope in the exact direction--
The moon should be your first night time target.
Good luck--
Joe L
  • 3186 Answers
  • Posted on Jun 18, 2009
SOURCE: manual tasco 302003
Sorry no manuals for these very small telescopes-- but Meade has a telescope similar to yours --- most likely--- go to this web site and download one of their manuals for free--
http://www.meade.com/manuals/index.html
Joe L
  • 3186 Answers
  • Posted on Dec 04, 2010
SOURCE: Hi, I NEED AN INSTRUCTION
All of Tasco's manuals are on this web site:
http://www.tasco.com/pages/instruction-manuals/
Why did my Tasco 119274cw camera stop taking pictures at night?
I found this, but perhaps there is no activity at night. Check it at 1:00am, the LEDs should glow.
Camera stops taking images or won't take images
  • Please make sure that the SD card is not full. If the card is full (display indicates "FULL", the camera will stop taking images.
  • Check the batteries to make sure that they are new alkaline or lithium AA batteries. See note above about short battery life.
  • Make sure that the Power/Mode Switch is in the ON position and not set to OFF or AIM.
  • Make sure that you are using a good quality SD card in your camera. Tasco recommends SanDisk® SD Cards up to 32GB.
  • If the SD card has its write protect switch in the lock position, the camera will not take images.
  • If you have used an SD card in another device before inserting it in your Tasco Trail Camera, you might want to try formatting the card using the "Format" option in Setup Mode (pg. 8). Make sure you have backed up any important files first, as formatting will erase all previous files. In some cases, other devices may change the formatting of the SD card so that it will not work properly with the Tasco Trail Camera.
Read more: https://manuals.plus/tasco/tasco-trail-camera-instruction-manual-119270cw-119271cw#ixzz7PnF3S7pS
When is tasco trail cam model #119256cw actually turned on
I can't see why you'd need to, but it can't hurt. The settings on the camera will be preserved as long as the battery's are left in.
1helpful
I need the user manual for my Tasco Trail camera model 119 215.
You can download the manual from the manufacturer's web site at
http://www.tasco.com/products/manuals/Tasco%20119215C%20TrailCam_2LIM_web.pdf
Dec 20, 2010 • Cameras
20helpful
I just bought a Tasco Digital Trail Camera - 119223C . During the setup my camera display also shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does...
I just bought,last August, a Tasco Digital Trail Camera - 119223C . Took pictures until Jaunary 2011, my camera display shows Loc and the SD Card flashes. The instruction manual does not reference this setup code. Does anyone know what 'Loc' means? I tried to reformat card, I also so not get a Y/N option for formatting. I bought a new card and changed batteries. no change!
3helpful
3answers
Where do i find a manual for a tasco model 119223c game cam
http://www.tasco.com/products/manuals/Tasco%20119223C_1LIM_web_rev5.pdf
Aug 11, 2010 • Cameras
Top Tasco Optics Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Tasco Optic Expert? Answer questions, earn points and help others
