Apple iPad Mini Logo
I forgot everything and trying to reset, but wont connect on wifi
How do I create a new id?
ONN tablet Google locked
If it is connected to WIFI,
Go to settings on your phone, go to connectivity, go to WiFi and then reset your password from there. If your Tablet asks you for a new password, then enter 12345 because that is the default WiFi password for all Android devices. After that, you can enter a new password and re-create your WiFi password.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Forgot iPad apple I'd and password
Go to https://appleid.apple.com/ and reset your id. You should have create security questions to answer. You had to use an email to create your id.
Wont let me create a google account or sign in to an existing one...says username..no matter what u use is in use...or cant connect to google...
It sound like your network connection is no active. If the device is new, try a factory reset and start over. Otherwise, of you can access settings check the WiFi settings. Forget the network and then reconnect.
Forgot my password
Hard reset the tablet and create a new account.
2answers
How can I get new password for my old apple id
JUST FOLLOW THE DIRECTIONS ON THE VIDEO THERE ARE SEVERAL VIDEOS ON GOOGLE JUST GO TO GOOGLE AND SEARCH FOR FORGOT APPLE ID PASSWORD.
I forgot my ipad mini password and I would a new one
Cannot get a new one! Factory reset from PC connection to iTunes!
Reset apple id account
Unfortunately, you will need to get to a laptop or tower PC or Mac, in order to reset your password, migrate to apple.com try to login, there should be a forgot password link just below the login entry points. The Mobile version of Apples website malfunctions when attempting to reset a password, this is why you need to go through a laptop or tower to have a successful password reset.
I cant unlock my ipad forgot my id can you help
You can connect your iPad to a computer and then do a factory restore to reset the device. After the restore you can set up a new password.
http://support.apple.com/kb/ht1414
Hope that helps!
1helpful
Apple id reset
I'm assuming you have already used iForgot etc to reset your password first or that you no longer have that email..
Go to settings, scroll down to itunes /App store.
Click on your apple ID. and you will get some options such as IForgot to send a new password etc. If you truly cannot get your password, then click Signout. Then you will be able to create a new one when you try to register, you may need to create a new email account if your apple id was linked to your old one. Your old apps that will not update, you can delete them by holding your finger on them till they wiggle and click the X. then redownload with your new ID. Hope this helps.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
