If you mean stream your movie from the blue ray to the phone, then yes
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
SOURCE: Sony Blu-Ray plays preview but won't play the featured movie
try clicking on chapters to access the dvd
hope this helps
kind regards and don't forget to rate us please
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
SOURCE: Letter box picture when viewing blue ray discs on Sony BR player
All blu-ray movies are in Widescreen format. So your tv converts the picture to make it look like letterbox. There will be some movies that will have those little black bars at the bottom. There will be some movies that don't. There is nothing to worry about it is normall.
Hope this helps
SOURCE: I have the LG BD390.
I had the exact same problem with my BD390 and another LG home theater system, both with the current firmware updates. I noticed others have posted this issue on various sites as well. I called LG and the guy I spoke with seems to have been coached pretty well on the scenes where this problem is occuring since he could sight the exact scenes that were giving me the problem. He claimed the blu ray probably isn't exactly 1080i or 1080p and that the player is probably having problems processing the resolution so I should lower it to 720p. This didn't fix the problem and didn't help explain why my blu ray player which plays plenty of other high resolution movies only has a problem with this movie. I think a firmware update is needed to fix the issue but I'm not holding my breath that LG will be proactive in getting that out soon.
Testimonial: "I think your right about the LG person. And maybe they will do a firmware update. So far this is the only movie. DVD of Iron Man II was fine. "
SOURCE: my sony blue ray player
I'm having the same problem. My BDP-S350 Blu-Ray Player used to play blu-ray DVD's but suddenly is unable to. Regular DVD's I can play. Please help!
