Pool & Spa Logo
Christy Love Davis Posted on Feb 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E70 and E90 error code on intex pure spa pump... what do these mean and how do I fix it?
rich2481
Level 2:
Sergeant:
  • Expert 291 Answers
  • Posted on Jun 12, 2016
rich2481
Expert
Level 2:
Sergeant:
Answers
291
Questions
0
Helped
105755
Points
834
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check with Intex for a repair manual ( On line and google..)
5 Related Answers
Mike Tellegen
  • 1631 Answers
  • Posted on Apr 11, 2015
SOURCE: We have a LED code showing on the new Intex pure spa. E97 Dry-fire Protection. What does it mean
Dry fire protection is when the heater has a call to heat but it is sensing NO water flow, therefore heater will be disabled.
A dry fire is when the heater comes on with NO water flow - damaging your heater beyond repair.
Causes: No water in tub, closed valves, clog restricting water flow, or the pressure/flow switch had failed?
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on May 22, 2015
SOURCE: I tried intex corp to get an o ring for pure spa, but they are out of stock. Wondering if anyone knew of retailer of intex who sold parts
funny,they have them now,
Spa Control Station Air Inlet Ring Replacement Parts Spas Store Intex
beau story
  • 108 Answers
  • Posted on Jun 05, 2015
SOURCE: I've got an Intex pure spa hot tub and the air bubbles button isn't working but the LED screen is on??? Any suggestions?
  • Do the other buttons work fine?
  • Did you press REALLY hard and break it
  • Have you tried pressing it REALLY hard when its not broken- Probably a bad idea
  • if you have the know how and the bravery take the face plate off (MAKE SURE THE POWER IS OFF AND THE WHOLE THING IS UNPLUGGED)!!!!!1
  • check the wires going to the back panel of the screen Rusted, corroded? Might be covered under warranty - refer to manual or look-up based on how long you've had unit
gizmothec85039
Greg Hoffman
  • 147 Answers
  • Posted on Jul 04, 2015
SOURCE: Have intex spa was working fine now comes up with E90 code
http://slink.intexdevelopment.com/faqsup/pub/FaqSupportServlet?action=getDoc&DocKey=4456&CrtLog=2015-01-19%2015:13:37&FileName=Spa%20E90%20Troubleshooting.docx
skythemike
Matt Davis
  • 3 Answers
  • Posted on Aug 12, 2015
SOURCE: I keep getting a E96 code on my intex pure spa and
RE: INTEX PureSpa - E96 error code.
This also happened to me, just after having it for 1 year. I followed the scanty instructions in the troubleshooting section to no avail. I called for "technical assistance" twice and got random females with heavy Asian accents and absolutely NO technical know-how.
ME: "I got a E96 error code."
AL (Asian Lady): "When you buy it? If less than year, we send new base."
ME: "It's been longer than that, can I just buy the base then?"
AL: "Yes, $380 and we send it you."
ME: "But I paid $350 for the whole thing new!"
AL: "It's cheaper just buy new one."
ME: "Sure, but can't we troubleshoot this one?"
AL: "We can no more troubleshooting."
No supervisor was available, I was told to hang up and try again for someone else. Persisting, I pried info from one that it was "pump bloken," from the other "bad consore." I believed both were full of it and had no idea what they were talking about.
MY FIX: I disconnected unit from spa. Removed console from base. Turned base upside down to inspect pump and find any ID markings. Found no obvious problem with pump or heating mechanism. Spend few hours time researching cost to buy identical pump. Gave up. Returned to unit, reassembled it, and it worked perfectly!
MORAL TO THE STORY: Intex products are fine, their Tech Support is a joke. I suspect the console had detected air in the pump and that it was stuck in a system error cycle which required a prolonged rest from any power input to refresh. Also, turning the unit over (while inspecting it) may have flushed any remaining water around the onboard pump sensor.
Don't listen to their know-nothing "tech support" when they suggest it is a GFCI problem, (or some of the others here who give this advice without really knowing).
Just keep it fully unplugged for at least a few hours to wipe the system memory!
Since it's a circuit board, it's like a mini-computer. Actually, it's just like a modem that requires resetting. If you unplug it and then replug it too soon, you've solved nothing, the on-board circuitry retains enough voltage to prevent it from resetting. You need to keep it unplugged for an extended period of time.
Hope this helps. Best of luck!
-Matt
Error code 90 on my Intex spa even after buying and replacing new pump . Checked for blockages but everything is clear. Got clean water in and new filter.
The E90 code on the Intex spa is due to a dirty water flow sensor. ... The black wire is plugged into a white wire, carefully unplug it and unscrew the sensor. Clean it good and blow out the hole it goes in. This will fix the code and you will be back in business https://www.justanswer.com/pool-and-spa/ap9qh-i-m-having-error-code-90-intex-hot-tub-intex.html
3answers
I have an e95 error code on my intex spar and it won't let me put the heater on
means temp to low and the last link is the answer from intex they stat to unplug system then replug but when the pump goes that causes same code since no water flow no water flow your pump has failed these pumps are a magnetic with a small ceramic rod to hold it in place the ceramic rod breaks and stops pump -- intex doesnt sell parts or replacement pump ---easy fix is to go to lowes they sell a brass rod about $4 or home depot and in welding isle is a package of brazing rods [[ brass ]] with a flux covering $ 10 dollars clean the flux off and measure rod about 3 inches is needed How to repair Intex PureSpa pump E90 Error 90 Intex Pure Spa E96 slow reset solution these links can assist http://www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action=openFaq&qid=608&lst_prd=853&lst_subcategory=854&frmcontact=
How to fix e90 code? is there a fuse or reset button?
Question
What does code E90 mean? What should I do if code E90 appears on my air bubble spa control panel?
Answer
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check the attached troubleshooting guide.
Pump is not pumping water on intex purespa error E90, what could be the problem?
I to have run into this issue and i saw a repair using a piece of brass rod. If you open the motor cap where the impeller is located you will find the impeller guide shaft is made of a cheep piece of plastic and has broken it is a magnetic motor guided assembly and all it does is hold the impeller in the exact place. well i have found just the piece that you can fashion a quick fix from and you can find it at any hardware store. I happened to get mine from home Depot. buy a toilet handle brass lift kit paid 3.00 for it.
the larger piece is a perfect fit cut it to size and file the end of any sharp edges. works great
2answers
E90 Error,How do I fix or clear the E90 error I am getting on my spa?
What should I do if code E90 appears on - Intex ' Frequently ...
www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action...
Jan 19, 2015 - What should I do if code E90 appears on my air bubble spa control panel? ... If alarm code E90 is displayed on the control panel, it means no ...
Oct 14, 2015 • Pool & Spa
Need wire diagrsm for a intex spa comtrol unit
How do you fix error code E90 in my intex pure spa pump? The control panel chirps and will not heat the water.
This fault code is No water flow sensed.
possible bad pump?
• Ensure the unit is plugged and switch on.• Ensure the outlet cover grid is clean and free
from obstructions.• Clean or replace the cartridge, see
Maintenance and Storage section.
• Ensure the in/outlet connections on the spa tub and filter pump are not blocked.
• If problem persists, contact Intex Service Center.
Corporate Tel # 1-800-234-6839
http://slink.intexdevelopment.com/b2cmnl/B2CMNLServlet?instantiate=B2cMnldownloadApp&action=pub_mnl&filnam=250IO_A0_1411_EN.pdf
http://www.intexcorp.com/support
How do you fix error code E90 in my intex spure spa pump?
You have an owners manual I hope, with
the codes & trouble charts
I would say call the pool & spa store & have
someone trouble shoot the problem
Nov 10, 2014 • Pool & Spa
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
