YES always replace the parts and keep safety for all if in doubt clean regulary the cilinder internally because its very thin These cylinders break easily if something is faltering.
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=NT+65GS&newwindow=true
SOURCE: Paslode finishing nail gun won't fire? Battery is
Give it a thorough cleaning.. if it still does not fire you might have to replace the spark plug.
SOURCE: hitachi nail gun,piston/nail push rod
You have one or more worn o-rings in the head of the gun. They direct the air to the proper parts of the gun to first drive the nail then to return the driver to the top of the gun for the next nail. Depending on the manufacturer and your model number, some companies make kits to replace the o-rings (always replace all of them). For some companies you have to get a breakdown of the gun and order each o-ring seperately.
SOURCE: My nail gun will only
it could be you are using the wrong nails, the gun should describe the correct angle and size.
SOURCE: my framing nail gun won't
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
SOURCE: My nail gun won't fire nails and is blowing It
Stop using it and take it in for service. If it is leaking air then an o-ring or seal may have failed (most likely guess) and it needs to be replaced.
