Televison & Video Logo
L
Lascelle brown Posted on Feb 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix my Samsung tv ..picture goes in and out intermittently
I have Samsung un40b6000vpxza tv ..the picture goes on and off intermittently sometimes...the audio and backlight are ok...could someone suggest what might be wrong..I already change the t-con board...
richie46
Level 3:
Top Expert:
  • Samsung Master 12,962 Answers
  • Posted on Feb 25, 2016
richie46
Samsung Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2941635
Points
58151
The inverter board is responsible for the backlight so you can see the picture. If the picture just goes off intermittently then that means that the backlight is being turned off. And since the inverter board powers the backlighting you might want to look there.
Samsung TV Flickering Issue Fix?
I'd look at a bad panel, the defective panel damaged your main, replacing that got it working somewhat but if it's on very long I'm guessing you will damage the main board you replaced. Try unhooking the ribbon connectors one at a time and see if half the picture works ok, if so you definately have a bad panel
I have a samsung Un55J6200afxza. sometimes when i power on the tv there is no backlight.
It could be a defective main board, or intermittent LED diode on the back lights strips.
I will try a new main board first.
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
Why does it switch on and off intermittently?
Check the power supply circuit for bad capacitors, you can tell which are bad by their bulging tops.
When I turn the television on, the red comes on, there is a clicking noise like it wants to come on and off. Audio comes on but no picture. Then audio goes intermittent. My question is what is wrong? Is...
If this tv is a Samsung HCM4215W with the symptom you described you are likely to have fluid leak on the board. Sounds like a classic fluid leak problem since the audio does come on and then going intermittent. If you find fluid from the tube(s) on the board then the set could not be worth fixing unless you can break up the fluid with degreaser spray. The fluid is conductive and will cause intermittent or shut down altogether the set. Look for the fluid as a clear substance. Also you may have a bad proscan board (module) Comes on with audio and no picture then on/off REPLACE PRO SCAN MODULE BP95-00077A. Do a search online for part for availability. But look first for the fluid leak.
Samsung 27" lcd tv picture goes black, still have
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!(*&^%
2answers
Samsung 40 inch LCD LNS4092D No Picture
You need to check the back light is still on when the screen is blank (check through the back).
If the back light is on, need to change the Powwer Board.
but,
no back light, need to change the inverter.
Picture goes intermittent after a while; sound plays throughout.
I would take it to a repair shop, they charge around $50 to look it over, and then tell you want is wrong with it and they will give you the cost to fix it. This is what I do when TV's go out. It will save you time and money in the long run.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
