Hello Warren, thank you for your post!
From what you have described there is water filling up the fabric softener tray in your Electrolux washer, EWFLS70JSS. At times water will fill into your fabric softener due to draining and siphoning action however, this is a normal operation within your washer. Hopefully this information is helpful to you. -Matt
SOURCE: Why does water remain in the fabric softener tray
If you are getting good water flow through this section on the final rinse then it can only be a blockage in the tray itself.If you take out the drawer by depressing the button in the centre of the drawer.then wash all the old detergent under the tap.Then remove the small insert in the fabric tray you will see normally 3 raised tubes,these need to be clear and also the part that sits over them,you should clean it thoroughly then refit and try again.
Hope this helps.
SOURCE: I have an Aqualux 1200 washer/dryer. After the
If the dispensers are in their proper spot it is normal for some water to be left in the fabric softener dispenser. When you add your softener add water to dilute it as some softeners are very thick and don't dissolve well especially in cold water
