I would attempt to turn iMessage (in Settings) off and then attempt to send messages, if this does not solve the problem I would contact AT&T to see if there is an error on their side.
SOURCE: I can't find my iCloud account to view my pictures
The Apple ID email address and password you use to turn on and use iCloud features and to access the web apps on iCloud.com.
You can use the same Apple ID that you use with iCloud to access many Apple services, such as the Apple Online Store, the iTunes Store, the App Store, and the Mac App Store. When you're asked to sign in using your Apple ID, enter the same email address and password you used to turn on iCloud.
You can find your iCloud account information in these places:
iCloud iCloud account
SOURCE: reset my icloud account
It will be your apple id which will be shown in the sveral times in settings. If you do not have an apple id or have forgotten it, you should head to this link:
Apple My Apple ID
SOURCE: I have an iphone 4s locked through icloud ,is it
hello !
unfortunately there is no way to bypass it till now,
the only solution is to replace the mother board which seems that you need to buy an other iphone
for Iphone 4 yes check this
SOURCE: How do i bypass the icloud activation lock?
I have given step by step process, this free to use....
Fisrt step you should do, Double click and Run the iCloud Unlock tool. After then Follow the installation wizard by clicking next, next until is ending and successfully installed.
On your desktop you have shortcut installed by the wizard, double click on it.
Press Check so the Bypass iCloud Lock tool can scan and find connected device and enable connection with the mimic server.
Enter your IMEI (unique 15 digit) and your Email ([email protected]).
Select the suitable Server for your Apple Device( Server iPhone 5c).
I have seen this press on Remove iCloud Lock website also you will get more information here.
