It initially appears to be charging but it doesn't. The red light doesn't come on and nor does the blue light flash. I have tried different plug sockets but with the same results. I bought my machine re-conditioned.
Hi Alvina, it's Jack at Dyson.
DC59 will display a blue indicator light at the base of the hand grip while the machine is taking in power. The light will go out when the machine is fully charged. DC59 will take 3.5 hours to charge fully when the charge is completely depleted, but it will take less time than this if there is still some charge remaining on the battery after use.
Please note, the machine's intelligent control software is designed to ensure the battery only takes in enough power to recharge, and to keep itself topped up. It's safe to leave the machine connected to the charger at all times when not in use - the machine is designed to be stored in this way, so it's always ready to go when you need it.
From the information you've provided, I'm not clear on whether or not you're finding your DC59 works as normal once the blue charging light goes out, or whether it's not working at all. To make sure everything is correct, please get in touch with our experts directly. We'll be happy to talk you through some simple diagnostic checks when you have your machine easily to hand.
You can reach the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
We'll look forward to speaking with you.
SOURCE: Flashing charging lights when on charger.
smething internal is burnt out possible bad battery.
SOURCE: The hand held dyson does not appear to charge.
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear. This can be quite hard work, and you may find a bit of additional leverage from a flat-blade screwdriver is helpful. It's a bit more difficult to answer your question about buying a new battery. The fact that the red light comes on would suggest that your charger is working, so the finger of suspicion does point to the battery, but without testing equipment it's impossible to be sure.
SOURCE: Handheld Dyson DC16 red charging
Sorry to hear you're having difficulties with your DC16. It's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting checks over the phone with you, and provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
SOURCE: DC31 will not run. When
From your description, it sounds like you may own a DC16, not a DC31. Due to the nature of the issue you're experiencing, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting checks with you over the phone. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
SOURCE: Hello, what is the significance
yes the reason the green and red light were flashing the way they are is because its a warning to you that the battery is either no longer good or there is problems with your wireing. Also those vaccumes were designed to not charge when there to cold or to hot as a saftey issue.
