Question about GE Clothes Dryer 5 Cycle Timer - WE04X10073
Dryer heats, but tumbles too slow
Heats, and tumbles so slow that it takes over 1 1/2 hours to dry a normal load. Sounds like the clothes are going up to the top of the drum and then dropping. Is this normal? I don't think it should take that long to dry, and should be a more consistent tumble.
  • Linda Hahm
    Linda Hahm Mar 07, 2016
    Thank you for all your suggestions....we will investigate further!
  • GE Master
  • 473 Answers
Without a model number this is just a guess. If your dryer is electric heat, you could have 1/2 of your heating element burned out. Some GE electric dryers have a 2 part heating element. One is used for gentle cycle and both come on for normal. One can be burned out and still work but takes twice as long to dry as normal, which is your exact problem. If its gas heat, then look for a blocked or bent vent pipe, or possibly a bad thermostat. Dryer drums do not turn very fast.
Posted on Mar 07, 2016
    New Friend:
  • 16 Answers
Has the fan cover housing been clean recently?
If your dryer is getting hot, but is taking very long dry a load, you may have an air flow problem
Posted on Feb 29, 2016
  • GE Master
  • 12,731 Answers
Could be a belt that is slipping.
6ya staff
SOURCE:
Haier not drying
Two possible causes. Try cleaning the fabric softener residue off of the temperature/moisture sensor. The other cause could be the thermostat has failed.
Jan 09, 2014 | Haier HLP21E Top Load Washer
My Maytag Performa electric dryer heats and tumbles, but the clothes take multiple cycles to dry, and water is pooling next to the left front foot. We cleaned the vent, replaced the vent hose, and opened...
two things come to mind; 1. although drum is rotating perhaps it is slipping under load. Change drum belt, and, 2. perhaps the problem isn't in the dryer, it could be that your washer is not spinning out properly leaving an inordinate amount of water in your clothes which would tax the performance of the dryer. Just a thought. good luck!
Aug 19, 2013 | Dryers
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Dryer heats but takes forever to dry the clothes, sometimes over two hours
sounds like your exhaust is either clogged or has a kink in the hose.
Mar 26, 2012 | Dryers
The dryer heats on and off. Sounds to be laboring to turn the drum. Service tech came out and did not know how to fix or approach the problem with why the dryer heats and dries a load and then may not on...
drum roller,drum glides, or idler assemblage which is located next to motor(might be motor going out). Here is a website that will help:
for glides/roller: http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
for idler/motor: http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Nov 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
My dyer heats and tumbles, but doesn't dry
I'd check first for clogged vent hose or clogged lint filter or clogged vent flap on wall (outside).
If that's not a problem, it may be a faulty thermostat. Heating element is probably okay if it heats some of the time.
More info, let me know.
Charlie
Oct 01, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
GE Clothes Dryer 5 Cycle Timer - WE04X10073 Logo
341 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
