No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Hello there...
I don't know if you have found already the one that's free but looks like you really need to buy its manual: Here.
Hope this helps... :D
First off, be sure that you are on the channel that you want to record!!
Press the setup button, the SETUP menu screen appears.
Select "timer rec set".
Then another screen comes up... select "new"
Enter your times, dates, etc.
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Please connect video out and audio out of your TV to video in and audio in of your vcr respectively.Switch on the TV and the VCR.Put the VCR on camera or AV mode.Press the record key on VCR.The VCR will record the programme being shown on your TV.Thanks.
