Radio Communications Logo
H
Helen Shapira Posted on Mar 01, 2016
Callers cannot always hear when we use our Sennheiser headphone
4 Related Answers
Anonymous
  • 903 Answers
  • Posted on Nov 21, 2008
SOURCE: dell inspiron 1520
Try uninstalling the software, then re-install it again and only plug the headphones in when asked to do so, this will enable the program to pick the headphones up and install the correct driver, if windows picks it up as new hardware and tries to install the drivers for it then it will not work correctly.
What version of vista are you using 32 or 64?
Anonymous
  • 155 Answers
  • Posted on Apr 24, 2009
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Anonymous
  • 123 Answers
  • Posted on Jan 05, 2010
SOURCE: Can't hear callers on my mobile phone
Your handset thinks that you have headphones connected.
Make sure there is nothing stuck in the headset connector port, and make sure it is clean.
If thats not the problem, then it may be cured via a software upgrade or it may need a hardware repair.
Either way your gonna have to take it to a shop to be done, unless youve got the required equipment to hand.
Anonymous
  • Posted on Sep 13, 2012
SOURCE: Sennheiser Hd 205 headphones stopped working properly
Although I'm not an expert I'm not quite sure if armadillopic is right. I had the exact same problem and managed to overcome it by replacing the cable from the headphone to the mini-jack plug. I actually only had to renew the last bit of the cable but chose to replace the entire cable. I found out that when I bend the last part of the cable in the exact right position the strange high pitched sound that was going over the vocals went away and the vocals became much louder and clearer like they normally did. Perhaps you can try if this works for you as well? Just bend the last end of the cable in various kinds of positions (NOT TO EXTREME OR YOU WILL ONLY DAMAGE THE CABLE MORE!). Hope you are able to narrow down the problem to just the cable. Greetings!
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
2answers
I have Sennheiser HD 570 headphones. The plastic headband is broken where it attaches to the headphone. Can I order a new plastic headband and is difficult to replace?
That part isn't available from Sennheiser. But they are pretty maintainable, if you're good with mechanical things, and if you can come up with another set of the same headphones for parts.
If you've already replaced your headphones and want to rid yourself of the broken 570's, I'm looking for a set to scrounge for parts.
11helpful
2answers
My sennheiser hdr 130 has no sound even though it has lights on its based and it is connected to my t.v. what is the cause of this problem and the solution?
This worked for me (this solution was posted on another thread). Unplug the base and take out the headset batteries. Wait 30 seconds. Reconnect. Turn on head set. I could hear immediately!
5helpful
2answers
2helpful
Bad battery
A replacement battery can be purchased from Sennheiser for $20.00.
Battery Part Number: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
1helpful
Bad battery for my Sennheiser HDR 45 headphone
Battery is: BA 151
Sennheiser Link:
Nokia E90 Communicator - callers can hear me but I cannot hear
Not certain... but you need to check menu - tools - settings - general - enhancement and make sure your default is set to "headset".
When you plug headphones only (not the headset/mic combo) into the 2.5mm jack, it will go into a headphone mode where you can hear through the headphones but you must speak through the phone microphone - it sounds like it is going into that mode on you. It can only be the setting above or possible a short in the jack (though that doesn't really explain why it is happening only when you receive a call).
If you have 2.5mm headsets (or can pick up a small 3.5 to 2.5 adapter), you can also try having them call you and see if you can hear through the headphones - that would prove it is going into headphone only mode.
Dell inspiron 1520
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
