Apple - iPad Air 2 Wi-Fi 64GB Logo
John Apthorpe Posted on Mar 03, 2016
Need to find my Email Password. - Apple - iPad Air 2 Wi-Fi 64GB
I need a code to unlock an account whom the other person can't remember the password
There is often a password reset button in which you enter the email used to sign up and it will send a new password to that email.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
2answers
How Do I reset email password
  1. Visit the email Forgot Password page.
  2. Select Password.
  3. Enter your full email address and your last name.
  4. Select Continue.
  5. From the drop-down menu, select I'll answer my security questions.
  6. Answer the security questions that you set for your account.
  7. Select Continue.
  8. Add a new password
  9. Select Enter
  10. Done. Your password will be reset successfully.
For email related errors and issues, the easiest way is to reach Email technical support service. Their experienced support team offers an instant solution and help for email setup and password related issues.
Dial directly toll-free number 1888-315-9712
email technical support number
Why is my email not working
This is a very hard question to answer without me actually being there to see how it is configured at the moment. If you go into settings, email, calendars, etc, look to see if your password is configured correctly. iOS email is not hard to troubleshoot, but one must be there to see how it is configured now. Tell me this, is this a password issue? Do you need to change your email password? If you have an external email account that is added to the iPad, the password that you configured on your external account is the password you have to use on your iPad. This would be where you would have to go and change the password and then put the password into the iPad. I hope I helped some. Check this link for answers.
iPad Mail Contacts Calendars Apple Support
Cant get into my email acc wanting email adress and password every time
It must be set in your account to do that, ask for your name and password. You need to go into your account you have with your tablet when you first set up the email address and change the settings. You may have not known that you checked the request for the name and password before entering. This can be easily changed. Just go into your email settings and look for the request to type in name and password and uncheck it.
I need to factory default my tablet
If it is an apple tablet that has Icloud and find my ipad on you can log in to his icloud account and change the password at Icloud.com
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
