This issue occurs when the external power supply has detected a fault.
The power supply has several built-in safeguards to help prevent damage
to either the console or to the power supply itself. The power supply
will turn itself off if one of the following conditions is true:
Under these conditions, the light on the power supply turns red.
Step 1: Make sure that the power supply is cool
loadTOCNode(2, 'whattotry');
The red light may indicate that the power supply is too hot or that it
has already overheated. If the power supply light is red, follow these
steps:
If the power supply light is still red, go to step 2.
Step 2: Make sure that the power supply is plugged in correctly
If
the power cord is plugged in to an extension cord, a surge protector,
or a power strip, the current or voltage that flows through the power
supply may not be correct. Make sure that the power supply is plugged
directly into a working wall outlet.
For more information about how to disconnect the Xbox 360 power supply,
click the following article number to view the article in the Microsoft
Knowledge Base:
906205
(http://support.microsoft.com/kb/906205/
How to connect and disconnect the Xbox 360 power supply
Step 3: Plug the power supply into a different wall socket
Try a different wall socket. Ideally, plug the power supply into a wall outlet that is elsewhere in the house.
