Question about Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR
Why can't I open a file downloaded from Tradebit?
What do I have to do to download from tablet to SD card
Insert SD card into your tab and make sure it is detected and accessible.
Download your files.
Open file manager on your tab and navigate to Download folder. Click to open.
Hold on the file(s) downloaded one after the other to select.
Top right of your screen or bottom right of your screen you will observe a set of 3 dots aligned on top of each other (i.e. if an options menu has not popped open); click on these.
Options to copy, share or a symbol like a Y turned on its side will become visible; select and navigate your way to SD card (still within file manager); click to open and then Paste/copy here.
A video tutorial would have been appropriate. Working on this please
Oct 11, 2017 | Tablets & eReaders
How do I read the ebooks on the sd card. The books show up. I press to open and it just opens another dialogue folder. HTML, contacts. Email and so on. But it won't open a book for me to read ?
Make sure eBook file are right format for your eBook reader app.
If yes- then open eBook reader app first, then find file and open it.
Feb 04, 2016 | Tablets & eReaders
How do i clear downloads.
Your tabet should have some kind of a File Manager in the apps main menu. Open it and look for the Download folder which should appear when you open the internal SD icon.
Open the Download folder and you should see your downloaded files. You have the option to select one or more of them and the selected ones you should have the option to delete. Use the three dots in the upper right on most file manages to choose delete, copy move etc. Be extra sure you're in the Download folder before you delete anything, though.
Mar 28, 2015 | Dragon Touch Touch R10 10.1 Google Android...
How do I open downloaded files?
I'm not sure what tablet and operating system you have but .exe files are typically Windows-based applications. Those won't run on a Android or Apple tablet, for example.
For viewing PDFs you need PDF viewing software. Again, depending on the tablet version you have you may need to install the appropriate version reader. PDF is an Adobe product and available from them for free. Adobe Reader Download Free PDF viewer for Windows Mac OS Android
Mar 13, 2015 | Tablets & eReaders
How do i open gmail attachment
It may depend upon the attachment itself. Safe the attachment to your download folder. Using a file manager, open the download folder and examine the file name. You can try to open it from the folder, but if you do not have the appropriate application (such as a PDF viewer for a PDF file), it will not open.
Locate an appropriate application for the file, load it, and you will be set for the next time you receive a similar file.
Mar 08, 2015 | Dragon Touch Touch R10 10.1 Google Android...
Tablet will download but says can t open file
You computer will download anything you tell it to but you have to have a program that opens that type of file. For instance, if it is a .jpeg image file extension then your computer uses a program like photoshop to open it. If the file is a music file with an .mp4 extension your computer needs Itunes to open it. Can you tell me what the extension is? A bit more info would be helpful for me to help you figure out exactly what to do. ;o)
Jan 23, 2015 | Tablets & eReaders
"Can not open file" is what EVERY Download reads. Samsung Galaxy note 10.1 is the tablet
Download appropriate application to view the file before you download a file , firstly install es explorer or solid explorer or any file manager. Then go to the downloaded location of file and open it, u will get to know whether you have supported application for that file you downloaded.....
Oct 24, 2013 | Tablets & eReaders
I cant find preloaded games on tabeo
1.) Download the "system.zip" file and unzip (using a program such as WinZip, 7-Zip, WinRAR, etc.) the file.
2.) You will then need to connect the Tabeo tablet to your PC and then select the "Turn on USB storage" option on the screen once it comes up.
3.) After the file has been unzipped it will need to be transferred to the main folder, or "root directory" of the Tabeo tablet. Please ensure that you do not place the "system" folder in any of the folders already in the "root directory".
4.) You will now need to have to go into Settings application (located under the apps list from the top right corner) and go down to "About tablet" and select Start Wizard. Then turn the unit off and on again.
Dec 25, 2012 | Toys R Us Tabeo
Why wont safari let open office download?
You have to download an app for documents like Open Office to download and open on your iPad. Safari won't let you download certain files from the internet. Apps like Downloads HD are one of those apps that lets you download almost anything from your iPad and open it from within the app or from another app that can open that file you downloaded.
Mar 11, 2011 | Apple iPad 32 GB 3G Tablet PC
Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR Logo
75 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
