The subtitles of the movies when using a usb flash drive doesnot read Arabic language despite that it works fine when using a dvd
SOURCE: Problems reading subtitle files
You should take it to the Vendor and he will replace it with a New one.
SOURCE: TV Remote Control doesn't work properly
The remote is almost surely doing what it was designed to do.
That just fails to cover what you want it to do.
This limited functionality is endemic among the so-called 'universal' remotes and they should be called 'multi-brand,' not universal.
Maybe we need a class-action suit?
SOURCE: Hi, how to enable subtitles for
It seems that subtitle file must have exactly same name as movie file. For example: Movie file: Mission impossible.avi Subtitle file: Mission impossible.srt or Mission impossible.sub or Movie file: Mission_impossible.avi Subtitle file: Mission_impossible.srt
SOURCE: My LG BD300 worked the other night and today it
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it
to clean the lens. If that doesn't solve the problem, get a screw
driver, open the player's cover so that you can gain access to the lens,
use a cotton board to clean the surface of the lens. This should clean
dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To
replace the lens, remove the bad laser, use it as a sample to get
exactly the same type and do the replacement. Note that replacing a
laser (lens) needs a professional touch, so if you cannot replace the
laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
