Washing Machines Logo
M
Michelle Mueller Posted on Mar 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Duet Front load is displaying E10 and F09 errors
R.A. Ellis
Level 3:
  • Whirlpool Master 12,731 Answers
  • Posted on Mar 06, 2016
R.A. Ellis
Whirlpool Master
Level 3:
Answers
12731
Questions
Helped
2618338
Points
59176
Search internet for:
Make + Model + the word "E10" and "F09"
Consult the owner's manual in the Troubleshooting section.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Error message : e01 f09
First try holding down the cancel button for 10 seconds and releasing (might have to do this 2~3 times). The technician manual is located under the lower front panel. I've heard that locating the CCU (brain box, in lower right) freeing it up and giving it a couple of wacks has worked. F09 is pressure switch, E01 is Thermistor. The tech manual will be a great help!!
Error code F09 for whirlpool
F09 Overflow condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
• Check / Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operation
Replace failed component.
Read more: http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz2e96NFcLn
Whirlpool duet f09 error code
it is an overflow condition caused by either a plugged drain pump or a bad pressure switch,if you hit pause/cancel and the drain pump continues to run then check the drain pump cleanout for foreign objects
1helpful
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
F09 code on front load washer. What is this?
F09 error means Overflow Condition.If the Overflow contact on the pressure switch is Closed for more than 60 seconds,Overflow condition will occur.In an Overflow condition,the Door will remain locked and the Drain Pump will run constantly,even if Pause/Cancel is pressed twice and the Display is cleared.
1. Check the drain hose and make sure it is not plugged or inked.
2. Check Wire Harness connectors to the Drain Pump,Pressure Switch and Central Control Unit(CCU).
3. Check/Clean Drain Pump Filter of foreign objects.
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off.
6. Check the Pressure switch for proper operation.
Is showing a flashing f09
Hello Sir, If the Washer is turning on itself then it is a CU Problem. It must be tripped or not functioning properly.
And about the F09 error. This error comes when the washer has a water overflow. This can be removed by tilting the Machine forward by making a point opened so that the excess water flows out. This overflow is caused when the water is blocked by any other object. This overflow is surely corroding the CU and making the machine to turn on by itself.
Kindly call a technician from Whirlpool to get the internal parts checked.
Thank you Sir, Have a nice day.
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Whirlpool duet dryer-error code e-1?
2helpful
F09 error code for whirlpool Model GHW9250MT
Please click on the following link for an explanation of the "F09" error code:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
Read through the information thoroughly and let me know if you have any questions, or require further assistance. I hope this helps you.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
