Exercise & Fitness Logo
A
Anonymous Posted on Mar 06, 2016
Horizon Fitness Treadmill new motor starts but cuts out in less than 5 seconds
I have just installed a brand new motor on my Horizon Fitness CST3.5 treadmill but I can't get the treadmill working again. When I switch the machine on the console works and the motor will begin to turn the belt but it cuts out after a few seconds. I have tried disconnecting the belt from the motor to see if that was causing the problem but the same thing happens, the motor spins but then stops within seconds. Can anyone help me fix this?
  • L Pfaff
    L Pfaff Mar 06, 2016
    Perfect, glad to here your up and running. That censor is probably the starter as I stated as being faulty.
greg kinsley
Level 2:
Novelist:
  • Expert 145 Answers
  • Posted on Mar 08, 2016
greg kinsley
Expert
Level 2:
Novelist:
Answers
145
Questions
0
Helped
83108
Points
273
No motor starter .... Rather a controller. Of you replaced the motor why was that and did a bad motor stress that controller? Model and year would help, also look for a small potentiometer on horizon boards that can be adjusted cw, clockwise gently and retry. Also, have you gotten the machine to calibrate? Unplugging cables and powering up can be fatal to some controllers. Missing roller feedback or encoder will also kill belt drive, these controllers are intelligent as to not cause injuries. Good luck.
L Pfaff
Level 3:
Top Expert:
  • Master 11,573 Answers
  • Posted on Mar 06, 2016
L Pfaff
Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3584929
Points
181713
Sounds like a faulty motor starter if equipped or motor it self faulty.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
  • Anonymous Mar 06, 2016
    Thanks for your answer - I found out that it was the sensor attached to the motor, by swapping it with the old one the problem has been solved.
  • L Pfaff
2answers
Horizon GS1035T Treadmill. Were are the fuses on it please?
https://support.horizonfitness.com/hc/en-us/articles/4410673893261-Horizon-Fitness-GS1035T-Treadmill
Horizon T5000 treadmill stopped working.
Question edited for clarity.
Question moved from Hoover Vacuums to Horizon Treadmill.
You shorted out the motor control board, you need a new one, or the old one repairing. It does have a circuit breaker according to the parts diagram so try and find that.
https://www.ereplacementparts.com/horizon-fitness-t500-tm30720082009-treadmill-folding-parts-c-201405_201552_201589.html
Manual
https://manualzz.com/doc/12277436/horizon-fitness-t5000-treadmill-user-manual
2answers
2answers
Where can I buy motor control board for horizon treadmill T101
just run in the open air, it's much better to experience real life
2answers
Motor not working
Unless you know how to use a multimeter I suggest calling a treadmill repairer . Home Treadmill Repairs Brisbane Brisbane Leading Treadmill and Fitness...
My Horizon fitnessT101 is brand new and i put it all together.Than i used the magnetic key and started it and the treadmill didn't start it just displayed E1 on the monitor.
Had same problem. I called horizon and after troubleshooting, they could not solve and replaced the entire circuit board. I was under warranty , so i was fortunate to not have to pay for one.
I have a horizon fitness t51 treadmill. I weigh about 138 pounds and typically run 5 miles a day at a 2% elevation at a steady speed somewhere between 5-6 mph. It recently has developed one of two...
hi,
from ur description i think ur treadmills control module have problem. motor driving card and motor is ok. normally there are no serviceable part inside the controlling module ( user interface module). only thing can do is remove the controlling module, take out its board check all the micro switches( press button switches) replace it found faulty or not( remember to remove the power before). the refix it and the test the tread mill.
ok
I have a Horizon fitness CST3 and the belt stops running but everything else stays on. Do you know what is cuasing my problem?
How old is your treadmill? Has the deck been lubricated? Do you smell anything odd when the belt stops? Unplug treadmill, remove motor cover and check cables are all connected.
Top Horizon Fitness Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
