Question about Acoustica Computers & Internet
My bacini acoustica keeps making this loud booming sound when i turn it on i left it on earlier on accident then i turned it off then i went to use it and its just making that noise
Its white
6ya staff
SOURCE:
Anonymous
  • 107 Answers
SOURCE: power steering went out and making a loud noise when turning.
yes power steering is most likely very low , repair leak , as the fluid is flameable
Posted on Feb 27, 2009
Anonymous
SOURCE: keeps saying no paper Makes loud clicking noise
The clicking sounds seems to be made by the small gears on the side of the tray. When you move the gears, it should push a plate beneath the paper upwards, and the paper with it, allowing the paper to be feed.
I'm not sure what I did to fix it. I removed the paper and cleaned both feeding rectangles (to the front of the tray -- nearest you). One is underneath the paper and the other is in the front, center.
I then made sure that, when I move the biggest gear (the one that isn't round) that the paper moves upwards.
Posted on Sep 01, 2009
charlymonty
  • 3741 Answers
SOURCE: steering wheel make a noise when turn left
its due to low/no fluid level in the power steering reservoir.Check the fluid in the power steering. If it is low the car will make noise when you turn the wheel. the internal parts gets rubbed hard and noise occurs. refill the fluid and let it reset for some time then try it will get the fluency to move smooth and noise will get stopped. -------- This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Nov 03, 2009
Anonymous
  • 102 Answers
SOURCE: BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Posted on Jan 02, 2010
Anonymous
SOURCE: I have Bacini Acoustica portable Wireless
You plug the transmitter power adapter into the back of the speaker then you use the dual rca cable to plug into the left and right outlets on the tv and into the adapter. Mine came with the pig tail cord.
Posted on Apr 07, 2010
Can anyone help me plz, i have a 37AW white knight dryer,my partner slammed the door too hard and the dryer hasn't worked since, has anyone got any ideas how to fix it, or tell me what to look for?
Probably broken the door switch which stops the drum when the door is opened. It may even just be the nylon strike pin that presses the switch.
White Knight 37AW Tumble Dryer Spares ' White Knight Spares
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw/catalogue.pl?path...ref...
White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 37 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Spring For Door Latch.
White Knight 37AW Tumble Dryer Spares - WhiteKnight-Spares, Parts ...
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw.../catalogue.pl?path... White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 36 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Door Window - Clear.
White Knight 37AW Tumble Dryer Parts ' Partmaster
https://www.partmaster.co.uk/tumble-dryer/37aw.../catalogue.pl?...whiteknight... White Knight Tumble Dryer parts - repair your White Knight Tumble Dryer with a ... White Knight 37AW Switch Strike ... White Knight 37AW Spring For Door Latch.
37aw white knight dryer door switch Google Search
Jun 06, 2018 | Dryers
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
Wall Plate teminals have the colors of Green, Red, Black, Yellow, White, Blue, Brown and Tan. Cable has the Colors White/Blue, Blue/White, White/Orange, Orange/White, White/Green, Green/White,...
see the table on this link:
http://www.server-servers.com/ge-cat5-network-wall-plate-straight-through-cable-setup/
GE Network Wall Plate Cat5 Ethernet Cable 1 Blue 2 Orange 3 Black 4 Red 5 Green 6 Yellow 7 Brown 8 White White / Orange Orange White / Green Blue White / Blue Green White / Brown Brown
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 15, 2011 | Computers & Internet
Wire order in new clip to replace broken end end 10 base T
From left to right:
1. White/Orange stripe
2. Orange/White stripe
3. White/Green stripe
4. Blue/White stripe
5. White/Blue stripe
6. Green/White stripe
7. White/Brown stripe
8. Brown/White stripe
Hope this helps!
Aug 07, 2010 | Unicom UTP Network coupler (ILC-S504C-SH)
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Hello I am new to the sewing hobby.My switches were fine during sewing a curtain then under & top stiches are a messed up. I rethread it might do fine 1/4 way down starts all over agian. Don't have a...
Here is a list of the model #s I found 1422 is not included are you shure about the #?
White 1077
White 1088
White 1099
White 1122
White 1202 1213
White 1240
White 1409
White 1411
White 1418
White 1466
White 1477 1488
White 1505 1510
White 1570 Classmate
White 1599 Jeans Machine
White 1600 Speedylock
White 1632
White 1700
White 1717
White 1760
White 1766
White 1787 1899
White 1800
White 1919
White 1955
White 1977
White 2000SM
White 2037
White 2134
White 2137
White 2220
White 2222
White 2837
White 2999
White 3077
White 3355
White 3900 F
White 4075
White 6477
White 7934
White 8000
White 8600
White 8800
White 8910
White Computer Machine
Nov 19, 2009 | Sewing Machines
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Cat 5 Issue you replied to
The color is not so important as the cable follow the same standard on both ends.
It has been my misfortune to find non-standard wiring in a facility, so long as they keep the relationship of the pins the same it will work, if the installer did not then you cannot trust any of the work and MUST either redo it all or have it all tested and certified by a cometent network cable installer.
568-B Wiring
Blue/White 4
Orange White 2
Green/White 6
Brown/White 8
568-A Wiring
Blue/White 4
Green/White 2
Orange/White 6
Brown/White 8
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Top Acoustica Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Acoustica Computer and Internet Expert? Answer questions, earn points and help others
