My tablketb only allowed use of 2gb of thge ram/memory. But Ty here still easy an additional 12gb of virtually untyoiuched memory remains . How do I grain access to thius memory??? Because I only can load 3 app and I updated one Third The apps available??
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
SOURCE: I try to download apps
First, you must be on android 2.2 or higher to do this. You can download the update here: http://www.archos.com/support/support_tech/updates.html?country=us&lang=en
Next, once you have the new firmware, you go to the applications menu in settings. Once there, select a program you would like to move to the sd card and in that menu press the move to sd card button.
SOURCE: how do I download apps to my cruz
This is real simple. You can use the cruz app store or...
go to the various online venders that you can download from. An example would be 4shared dot com. Search amazon.apk and download and install this. This will give you access to the amazon app store. If you root and flash to JGM ROM or Macho ROM (both of which are great) you will have the android marketplace. You can just download the .apk's (which are like a zip file of the app) online by searching the app name and apk. You can put them on your sd card or download them from the browser on the tablet. All apps downloaded this way will be free and doing this does usually break the copyright so check to make sure the app is free and has free licensing so that you dont do anything illegal ;). gluck
Some software will be automatically updated but needs human to permit this. Suggest you contact Samsung why this happened.
Android 4.0 Tablet PC
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
