As you're mixing brands and models, bestmake sure everything is in phase.
SOURCE: Connect Qsc pair kw122 powered speakers and kw 181
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
SOURCE: what fuse does a Peavy Mace take
depend of the power I= P/E 15-20AMP FOR 22O VAC
God bless you
SOURCE: my peavy 118 subs dont play as loud anymore what could be the problem.
Circuit resistance from corrosion, or broken strands int he flex wire connections between voice coil and the terminals. It is also possible the voice coil form is distorted. It is also possible a capacitor in the amplifier is in the early stages of failure.
SOURCE: The SP5G Peavey Speakers are a good combination for the MP5 Plus?
Those speakers are capable of much more power than that little powered mixer can deliver - my 5G's are rated for 800 Watts program. I use a pv2600 to drive mine - at 8 ohms per side that's a good match. Depending on what your using the setup for...my concern would be that a small amp like that could get turned up high enough that you'll be clipping - thereby sending nasty squared waves at the speakers - they won't like that much. If you want much volume - you should look at a bigger amp. If you're going very low key...those speakers are overkill.
4000 people is a lot of people to cover in any location so if you give me more detail of the location I could give you far better help than I had
