Good Morning Denise, thank you for your inquiry!
From the information you have provided your Frigidaire freezer is making a buzzing noise and it will not stop. You may need to perform a reset on your freezer and you can do that by disconnecting the power cord for at least ten minutes. If the buzzing continues I would be happy to research your freezer further, in order to do so I would need your model number. You can locate the serial tag (which lists your model number) on the inside wall. Once I have that information I would be happy to help you further. -Matt
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
loud buzzing I believe is an alarm that is waring you that the freezer is not cold enough. Door problems can be fixed. Test is to stick a dollar bill in the door and shut it. It should be a little hard to pull the bill out. Do this all over the door and find all the bad places. One problem is that the door can become warped by banging it against something or kids hanging on it etc. If you can see the warp you can actually bend the door back into place by holding the bottom of the door and moving the top in the necessary direction. Like jamming your foot against the bottom and pulling on the top or putting a box at the bottom of the door to hold it open and push the top. Next many time the bad fit door is because a hing has moved. All the hinges are adjustable. Usually you loosen the screws and move the door in the appropriate direction and re-tighten the screws. These screws are very tight so you need a big screwdriver and someone big to turn it. Lastly you can purchas a completely new door seal and put it in..
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside.
There is a fan underneath accessed from the rear behind the cardboard backing.
The compressor is also there with a starter/overload relay which could make the noise.
the loud buzzing is the freezer high temp alarm. dont know why its warm though. make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
