How do these keys work? MC I MR I MRC II M- I M- II M+ I M+ II ??? How does one save a number to memory, then add or subtract a second number to it? How to clear memory? How to recall the number in memory? Thanks! Richard Driggers
Memory keys normally work by adding and subtracting values to them. It looks like you have two memories available, memory I and memory II. (M- I M- II M+ I M+ II) You recall these values with the MR(C) keys to use them in other calculations. Finally, you can clear the memory using the MC keys. Sometimes there is not a MC key. In this case, the easiest way to clear the memory is to recall the memory, multiply it by -1, and add it to the memory. This should set it back to zero.
As an example, if we enter 5 M+ I, 10 M+ I, and then hit MR-I, we should get the answer of 15. If we then enter 13 M- I, and hit MR-I, we should now get an answer of 2. Now if we hit MC - I and then MR - I, we should get the answer of 0.
Let me know if you have any questions.
Good luck,
Paul
Hi, here are some of the answers to your questions.
GT:- Grand Total: It shows the cumulative total of your calculations
MU:- Mark Up: It is used to calculate the CROSS PROFIT MARGIN in business environment.
MRC:- If pressed once, it shows the number stored in the memory. If pressed twice it clears the memory.
AC:- All Clear: It clears everything
CE:- Clear Entry: Clears the last entry of calculations.
ON/C: If the calculator is off, it turns it on. If the calculator is on it clears all entries.
If you have any more questions you can visit this site: http://www.aurora-ltd.co.uk/OpInst/FunctionsGuide.htm it has almost everything covering the calculator buttons.
Lujaina96
