In regular wash cycle washer fills then only agitates for 3 min. then soaks 15 min, agitates again 1 min. drains, rinses, spins, wash light stays on through all cycles, starts over during second cycle spin light stays on from agitate to finish, only agitates 1 min. twice, Is it shift actuator. thank you kirk
SOURCE: I own a Maytag Performa
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
SOURCE: washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
SOURCE: washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
SOURCE: washing machine not agitating during wash cycle. Only when rinse
This occurs when your transmission has failed & requires replacement.... Good luck!... Bill
SOURCE: maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
