DWT 55500
SOURCE: Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
SOURCE: Water is settled at the bottom. Filters have been ...
My dishwasher did the same thing after a cycle was interrupted. Try putting your hand under the handle and firmly pushing against the top center of the door so the actuation of the switch is completed (the switch is in the door on my model and I suspect the actuator's travel is not getting completed).
Worked for me after pushing every combination of buttons and waiting for anything to happen.
PS: I pressed the START/CANCEL button during power up and the display showed IF for 5 secs then showed alternating H/H6. Anyone know what that means?
SOURCE: dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to
check for the water inlet hose, the water inlet valve and the float switch
assembly. When the water fills your dishwasher, a float rises along with it. As
the float reaches a certain threshold level, it shuts off the flow of water,
thereby preventing a leak. Sometimes the float can get stuck in the wrong
position in your dishwasher, and it can prevent your dishwasher from filling.
Sometimes it can happen due to float valve and on other occasions due to float
switch. Inspect the water hose coming to the dishwasher for any blockages. If the
hose is not clogged then check the water inlet valve for any clogs, if the
water will not even fill for few seconds then certainly the water inlet valve
is bad and should be replaced. You can also use a multimeter to check
continuity on inlet valve. If you don't get any value on the multimeter then
you'll need to replace the water inlet valve assembly. However, if the valve is
fine then the float switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
SOURCE: boscsh shu3322uc dishwasher won't fill. If I put
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
SOURCE: Frigidaire model # GLD 2250 RD 85. Won't fill with water
see this causes and fix it. God bless you
If there's no water entering your dishwasher, check these:Water-inlet valveFloat switchWater-inlet valveThe water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.Float switchThe float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. To determine if the float switch has failed, watch the part testing video at the bottom of this page.
