Haier 3.6 cu. ft. / 102 liter Chest Freezer HCM036PB Logo
b
brenda berg Posted on Mar 16, 2016
Please how to change the green bulb model#BD101G
The blue temperature light and the green light is flashing on my danby deep freezer. Why is this?
One of these is a power light. It typically remains on while the freezer is in use. No light means either a blown bulb or no power. The other is associated with the thermostat. But it does NOT indicate that freezer temperature is appropriate. Flickering appears to indicate the bulbs are simply failing. The bulbs are neon, I think, and are not cheap. Some might try replacing such with LEDs. I have seen comment that the bulbs are not long lasting. www.manualslib.com has numerous danby freezer manuals but I do not know your model. Have a look.
How to change a bulb behind the control panel on the front of the freezer?
look for the screws that hold it together look under the seal for screws
Oct 13, 2014 • Freezers
How to change the bulb on my freezer?
led's become weak over time. it is only an indicator that the power is on. Leave well alone!
Oct 01, 2014 • Freezers
1helpful
Light bulb is not working. how to change it and what kind of bulb is it model: FKFH21F7HW
Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Skandiluxe freezer seals
Hi
Most freezer lights are screw on bulbs. Unscrew the bulb unticlockwise and replace with a new one.
Feb 15, 2014 • Freezers
1helpful
2answers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 • Freezers
The green light on the front indicator panel is not working, although the ppliance is operating normally. Is the lamp replaceable, and how do I get to it? Does the front indicator panel open, and how?...
to be honest the price would not be worth the cost. but yes you can replace bulb. all you have to do is click it off. but do get in touch with manifactors Manual for blub size and info.
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
