Question about Tablets & eReaders
How do I reset it - Tablets & eReaders
  • Tablets & eR... Master
  • 1,682 Answers
Hard or factory reset is also called as master reset
  1. Power the device off. ...
  2. Press and hold the Volume up button then press and hold the Power button.
  3. When the Samsung logo appears, release all.
  4. Select wipe data/factory reset. ...
  5. Select Yes -- delete all user data.
  6. Select reboot system now.
How Do Hard Reset My Samsung Galaxy Tablet Perform hardware factory reset Samsung Galaxy Tab reg 2 10 1
Posted on Mar 16, 2016
6ya staff
SOURCE:
Reset my proscan notebook plt1035
I cannot find that model number is it a tablet or is it running windows?
if tablet
How to reset Proscan PLT722 when you forgot your password or unlock pattern. How to remove unlock pattern on your Proscan PLT722 android tablet
To reset this tablet is a little bit tricky, because there are no physical Volume keys on the device, but we have a "hidden" RESET hole (on the side of the tablet) and using this we can easily do a factory reset on the tablet to remove the password and get access to it.
Using the Hard Reset (Factory Reset)
If you want to restore your Proscan Android tablet to its original condition, use a Hard Reset (Factory Reset) to initialize it.
1. Turn the power off.
2. Find the tiniest RESET hole on the side of the tablet next to the micro USB charger port and use a paper clip or similar tool to click it, press gently the RESET button in the hole. While you are pressing the reset button press and hold the Power button also until the Proscan logo comes up and the Android robot is displaying on the screen. (Note this is not the RESET hole on the back of the device.)
3. Release the Power and the reset button.
4. To get into the Android recovery menu you have to click it push it down again the tiny little RESET button in the hole and the POWER button together. Keep pushing the two buttons until the recovery menu displayed.
5. To highlight the options use the paper clip and press the RESET button to move down the highlighter bar until you get to Wipe data / Factory Reset. Press the POWER key to get in the next menu.
6. Move the bar again using the reset button and highlight Yes -- delete all data and press the POWER button.
WARNING
If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to backup any important data before performing a Hard Reset.
Proscan PLT722 soft reset or restart the device when it is frozen If device is hanging, use a small pin or paper clip to press Reset hole on the back of the device, it will forced shut down and the device will power on again.
Proscan PLT722 factory reset from the menu Factory data reset - Reset your settings to the factory default values and delete all your data. If you reset the tablet this way, you are prompted to re-enter the same information as when you first started your Android tablet.
Go to Settings > Backup & reset > Factory data reset > Reset Tablet and confirm
All data will be deleted!
Check the software version on your tablet: Settings > About tablet> System updates > Check now.
NOTE: Your personal data from internal phone storage - including information about your Google account and any other accounts, your system/application data and settings, any downloaded applications and your DRM licence - might be lost in the process of updating your phone's software. Therefore, it is always recommended to backup your personal data before updating your phone's software.
Jan 23, 2018 | Tablets & eReaders
Tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
on Sep 27, 2010 | Apple iPad (16 GB) WiFi Tablet PC
How to do a hard reset
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Dec 18, 2015 | Tablets & eReaders
Does anyone know how to reset my kids Click N Kids tablet?
Hard reset or soft reset? Softreset, push a pin into the reset hole on the back or side. Hard reset, hold down vol- and power until the reset screen appears.
Aug 03, 2015 | Tablets & eReaders
How do I do a auto hard reset on my polarold internet tablet pmid701c and can it be able to download Google plays tore
Differnt hard reset/factory wipe methods for tablet pc, Hard reset or factory wipe is amethod of formatting any android device ( tablet or mobile). by doing hard reset all the apps and files that are installed or created.
How do i hard reset a polaroid t7 internet tablet? - my, Cannot factory reset polaroid internet tablet. how to hard reset a polaroid tablet model # pmid705x? i`m locked out of my polaroid internet tablet model ptab7xc i. How to hard reset android phones & tablets, restore to, Under the personal data heading near the bottom, you'll see an option to perform a factory data reset. select this option. if you're running android 2.3 or above, you.Hard reset - mobile recovery website, Hard reset ' follow @hard_reset new.hardreset.eu site would you do a hard reset of your device to wipe the data and start over? if you are about to sell your.
[how to] perform a factory reset - acer android tablet forum, Do not perform this factory reset procedure if you have an unlocked tablet and/or a custom recovery!!!! the factory data reset is a standard feature in android devices.. S7 factory data reset - southern telecom, S7 factory data reset if you have set a p.word on your tablet and forgotten the p.word, follow the instructions below to reset the tablet.How to factory reset an android tablet - pc advisor, Factory reset android tablet,google, android, tablet comments. lordganzgee said: i cant go to setting optionshow to reset my google account or p.word in my tablet.
Feb 25, 2015 | Tablets & eReaders
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabi™ Sync.
Dec 20, 2014 | Tablets & eReaders
How do i do a hard reset on my kurio kd interactive
To factory data reset a kurio 7, Click settings Scroll down to Backup & reset Click Facotry data reset
Click Erase SD card to erase an SD Click Reset tablet -
Nov 28, 2014 | Tablets & eReaders
Reset hp slate 7 to factory settings
  1. From the Home screen, touch the All apps ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687853.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken icon, and then touch the Settings ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687854.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken icon.
  2. In the Personal section, touch Backup & reset . Figure 1: Backup & reset
    ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687855.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken
  3. Touch Factory data reset . Figure 2: Factory data reset
    ?javax.portlet.sync=ada14e3e822cc03c3ab7f3e532a15c01&javax.portlet.tpst=ba847bafb2a2d782fcbb0710b053ce01_ws_bi&javax.portlet.prp_ba847bafb2a2d782fcbb0710b053ce01=wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d&javax.portlet.rst_ba847bafb2a2d782fcbb0710b053ce01=wsrp-url%3dhttp%253a%252f%252f16.193.225.56%253a50002%252fsp4tssearch%252fimageservlet%253fdocid%253demr_na-c03678322-4%252fc03687856.jpg%26wsrp-navigationalstate%3ddocid%253demr_na-c03678322-4%257cdoclocale%253d%257ccalledby%253d%26wsrp-requiresrewrite%3dfalse&javax.portlet.begcachetok=com.vignette.cachetoken&javax.portlet.endcachetok=com.vignette.cachetoken
  4. Touch Reset tablet .
Sep 21, 2013 | HP Tablets & eReaders
How to unlock the administrator password
Use windows password reset tool is the best way to recover admin password
Here are three tools for you.
Windows Password Reset( http://www.windowspasswordreset.net )
Windows Password Recovery Tool ( http://www.windowspasswordsrecovery.com )
Windows Password Crack( http://www.windowspasswordcracker.com )
Jul 19, 2012 | eMachines eM250-1162 Atom N270 1.6GHz 1GB...
Tablets & eReaders Logo
241 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
