SOURCE: washer stopped midcyle-error code do, then FL
The door interlock could be faulty. The only way to open the door if the door interlock is faulty is to remove the top of the machine, after turning it off at the wall and pulling the plug out of the socket, and locate the door interlock from the inside. There should be a metal "slide" which can moved back to release the door catch. The interlock could be warped from getting hot, which will make the slide almost impossible to move. Remove screws holding the interlock from the front panel and from the inside pry the interlock from the catch. Replace interlock.
SOURCE: Door will not lock
Faulty Latch ,, i would order and replace the latch assy, you acess the latch by removingthe 4 screws in the dispensor assy, the n remove the door, andthe 2 screws opposit teh door hinge. then the front "u shaped" panel will come off and then just 2 5/16" screws on either side will release the main top assembly allowing you to tip it backwards and gaining acess to the latch assy
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
SOURCE: have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
