Samsung Galaxy s2: Uninstalling Apps that came with the phone (no computer):
Hello. Not every app will be able to uninstall if it comes with the phone. If you are not using them, they aren't doing anything to your phone except taking up a small amount of space. Remember, if an app is uninstallable that came with the phone, you will not be able to get it back, even if you factory reset the phone.
If you are sure you want to try and uninstall or disable apps on your phone.. this is the procedure:
Settings > Application Manager > (slide the screen all the way to the right) ALL > (tap on the app(s) you want to uninstall or disable (next to Force Stop button there's either an Uninstall button or there's a Disable button
To remove the ones that are not uninstallable, you will have to ROOT your phone. Note if you ROOT your device and you mess up on the instructions, you can potentially mess up your phone making it unusable. Also, if you ROOT your device, you will not be able to get any kind of servicing help from the manufacturer. (this is for advanced users). Once you ROOT the phone, you will have administrator rights over all files on the device, if you accidentally uninstall an application that you think you do not use, but the phone needs to have, you can mess up your phone. Think about this need to uninstall these apps before deciding that it is a must do. This may be more trouble then it is worth. Why not just DISABLE them instead. Remember: Should you want to sell your phone.. if you uninstall an app that came with the phone, you can not get it back even if you Factory Reset the device.. It will be gone forever.
A lot of people are obsessed with disabling and removing apps when it is not necessary.
HowtodownloadanddeleteAppsonaSamsungGalaxyS2-O2GuruTV.mp4
