This error indicates a memory problem.
The camera can't read or write data to the memory card. Try turning off and on the camera again, or take out and reinsert the memory card several times. Also remove and reinsert the battery.
It also can mean the memory card is not formatted, or there is a format error for an other reason. Format the internal memory or the memory card.
It also could mean the memory card is damaged and can't be used any more. Then you have to place a new memory card.
I hope something will help.
This is also in you user manual.
Your pictures are corrupted.You can recover pictures from memory card with this 1. Do not save any new photos into the memory card of your camera. 2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer. 3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked) http://www.any-data-recovery.com/product/datarecoverystandard.htm 4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your currupted pictures.
1) Using new memory card. first connecting memory card to computer and format. and insert memory card to camera. making single shot. then connecting computer you see picture. Memory card formating in camera may be not working computer or other device.
Format memory stick through Format option in camera Menu. Please note that all data on memory stick will be deleted by formatting it and memory stick will be refreshed. Now take pictures and check does camera saves/ store. Thanks.
Please try to take as many pictures from memory stick as you can then format memory stick through format option in setup. Hope this will resolve this blue access issue. You can use another memory stick like 1GB in this camera.
- Turn off your camera and take the batteries out
- Then take the memory card out
- Leave the batteries out for around 10 minutes
- Then put the memory card back in
- Then put the batteries back in and turn the camera on
- Try to see the pic/watch movie again
If this didn't work, check the memory card with a card reader...if it still gives an error then the card might have malfunctioned or needs a reformat.
Try putting in a different memory card that you may have lying around and see if you can still take pictures and videos. If that works then you may need to go into setup via camera and format the memory card. If another memory card doesnt work it may be the camera. Let me know if this method doesn't work and I could be more than happy to give you another solution.
It might be time for a new memory card.
A last effort you can try is to remove the memory card and insert it into a memory card reader connected to a PC. There are diagnostics and utilities that can be performed on your memory card since it will be treated by your PC as a removable storage. You can format the memory card, run diagnostics like Norton Disc Doctor or similar.
If in any test an error shows, then you have just confirmed that is due for replacement. If after formating, scanning and checking it shows good, then you can try using it again.
You can also try cleaning the little gold tips at the end of one side of the memory.
Hope this be of some help/idea. Post back how things turned up or should you need further information.
Good luck and kind regards.
