Question about Maytag Atlantis MAV6000 Top Load Washer
How do you take the washer apart to repair yourself
    Habit-Forming:
  • 59 Answers
Try to follow manual and there some video on youtube.com which might help u
Posted on Mar 17, 2016
    New Friend:
  • 59 Answers
There are 2 screws behind panel. Remove to lift panel, remove the 2 clips and disconnect lid switch connector. You can then lift body off frame.
6ya staff
SOURCE:
Replace windshield washer hose on 2010 ford focus
Broken at the hood?DO NOT use Ford parts.Best repair is ......go to a "upull parts lot" this is where you remove the car parts yourself,find an older Hyundai Accent 2003 2004 style and pull the windshield washer hood squirters and hoses off the hood.They will fit right on your 2010 Focus hood.Bonus.... they will never break apart like the plastic Ford ones.Just attach the Hyundai rubber hose onto your plastic feed line on your Focus on the passenger side.
Oct 01, 2018 | Ford Cars & Trucks
My washer won't spin & rinse
the wigwag switch may need to be serviced.
have someone come look at it and watch what they do taking it apart...
when they have it apart and tell you what is wrong... and what they are going to charge to fix it, if the repair is more than $50 tell them you will just fix it yourself.(the part is $23 at the local applience parts center)
Mar 25, 2013 | GE WDSR2080D Top Load Washer
Over loaded my front load lg washer and now it is not able to spin. Makes awful grinding noise. Is this something I can fix myself?
this hapened to me years ago it was an easy fix I took apart my washer ther should be a belt that almost looks like a belt off a car it probably went off track once you get it apart try spinning the belt you should be able to fix yourself
Jul 06, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore washer Actuator problems
you need agitator dogs, should only run a few bucks. You can order them at marcone.com with your model #, then take the agitator apart and replace. very easy repair you can do this yourself
May 03, 2012 | Kenmore Washing Machines
Drum is loud during spin cycle
A loud whinning or rumbling sound when it is in the spin cycle means that the bearings in this washer has failed. It is an expensive repair since the washer has to be torn complete apart to get to the bearings. Also, the manufacturer does not sell you just the bearings and seal but, you must buy the rear tub with the bearings which raises the cost of the repair significantly. For example the rear tub for this washer can cost $250 not including the shipping. So get a few estimates before deciding whether to repair or replacing the washer.
But, if you have the mechanical ability to do the work yourself and you are interested in getting the bearings and seal parts to get your washer going again. There is this site that has videos describing what it will take to fix this washer and will sell you the neccessary parts. The link to this site is: http://www.hometask.com/washerrepair.aspx
Feb 22, 2011 | Frigidaire GSTR1670A Front Load Washer
Oven door does not consistantly shut completely
There is alot of unit that I personally repaired for the same problem. I designed a quick fix for it without changes the hinges. It is a little bit technical. The door has to be to took apart and in will need three washers on both sides of the hinge. this will be a $1.00 do it yourself fix if you dont have any coverage.nyc appliance repair can fix it for you.
Feb 02, 2010 | Bosch HGS 255 Gas Kitchen Range
Durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Aug 12, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Hello!
This is similar to the Red Lights Of Death. But instead of your CPU having a bad connection, it's your GPU. There is a 3 year warranty on the 360, so call Microsoft and get it repaired or replaced. If the warranty seal is broken you can take it apart and replace the x-clamp with 4 screws, 8 fiber washers, 8 steel washers and heat sink paste. Contact me for further instructions if doing it yourself. I hope this helps.
Good luck and happy gaming!!
Aug 19, 2008 | Microsoft Xbox 360 Console
My roommate removed the water in hose and I need to find a manual to put it back together
starslight07 You can find the repair manual for your washer here: http://tinyurl.com/32d5lu Good luck. Gendos
Jul 06, 2007 | Whirlpool LSR9434PQ Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
55 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
