Amazon Kindle 2 Logo
Aundra Shields Posted on Mar 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After update and fully charging, unable to connect even after restarting as instructed
Software version 2.5.8
Ravi
Level 3:
  • Amazon Master 1,682 Answers
  • Posted on Jul 20, 2016
Ravi
Amazon Master
Level 3:
Answers
1682
Questions
Helped
579599
Points
8910
Hard and Soft Reset
  1. Make sure the Kindle is turned ON. ...
  2. Press the Power button for at least 20 seconds. ...
  3. Wait for it to reboot - wait a minute or two. ...
  4. Your kindle should be back to a responsive state.
  5. You will have to go through the setup again and then synchronize to put your e-books and other data back on the device.
When using my kindle reader and going to the next page all I got was a blank page and have not been able to get anything else. The reader is less than six months old.
If you are experiencing a blank page when trying to read on your Kindle, there are several things you can try to resolve the issue:
  1. Restart your Kindle: Press and hold the power button for about 20 seconds until the device restarts.
  2. Check the battery level: Make sure that your Kindle has enough charge to function properly. Connect it to a power source and let it charge for a while.
  3. Check your internet connection: If your Kindle is connected to the internet, make sure that your Wi-Fi is working properly. Try disconnecting and reconnecting to your Wi-Fi network.
  4. Check for software updates: Make sure that your Kindle is running on the latest software version. To check for updates, go to "Settings" > "Device Options" > "System Updates".
  5. Remove and re-download the book: If the problem persists with a particular book, try removing it from your Kindle and re-downloading it.
If none of these steps work, you may need to contact Amazon customer service for further assistance.
2helpful
2answers
How to update Kindle e-reader software?
Amazon.com Help: Kindle E-Reader Software Updates
www.amazon.com > help > customer > display
These free software updates include general improvements and performance enhancements. Note: Determine what Kindle E-Reader model you're using before ...
Amazon.com Help: Manually Update Your Kindle E-Reader ...
Manually Update Your Kindle E-Reader Software. Using a computer, download the file for your Kindle from Kindle E-Reader Software Updates. Turn on your Kindle. Connect your Kindle to your computer using the included charging cable. Drag and drop the downloaded update file from your computer onto the "Kindle" drive.
Kindle E-Reader Software Updates - Amazon.ca Help
www.amazon.ca > help > customer > display
Kindle E-Reader Software Updates. Software updates automatically download and install on your Kindle when connected wirelessly. These free software updates ...
How do I fix kindle update error
General issues related to kindle updates Kindle software update Errors sometimes can give you little trouble and Amazon has a troubleshooting process to fix the kindle update issues. Choose to update the kindle device manually with these step by step instructions. First it important to understand what kind of update the kindle device needs. The kindle fire or kindle e-readers update automatically when connected to WiFi and sometimes the end user ignores the prompts for downloads. Before you begin the updates check to see if your kindle device current software version.
Now, to find out if your Kindle is on the latest version , Launch the Menu and then go to Settings. Look for the version number at the bottom of the screen and cross-check with Amazon kindle support page. Amazon keep of pushing new firmware updates to every single Kindle released . If your software version is higher than the version listed in the table, your device does not require an update.
Now if you would like to run and manual update follow these instructions:
How do I updat my ipad
There are multiple ways to update iPad. The easiest way is to do that in the Settings app. Follow below steps to reach the aim.
1. If a pop-up panel tells you that iTouch latest version is available, you can then tap on the button of "Install Now" to begin to update to apple iOS latest version.
2. You can also manually check out if the apple iOS latest version is available now. Now you can follow the steps shown below to have a try.
a) Connect your iPod to good Wi-Fi connection and make sure your iPod storage is enough and the battery is able to support the iPod update.
b) Click on "Settings > General > Software Update" successively.
c) When your iPod has detected an apple iPod latest version, you can click on the button of "Install Now". If a dialog requires you to delete some apps temporarily because the new version needs more storage, you can click on "Continue" to uninstall the apps. If you click on "Cancel" button, your apps will not be uninstalled.
d) After that, iPod will begin downloading and installing the apple iOS latest version in no time. Wait until the update is finished.
The process to update to iTouch latest version is not hard at all. Actually, before the update, you can manage your iPod files to make some room for the new version or to make the process much smoother. The next two parts will instruct you how to manage files via iTunes or iTransfer in detail.
For more methods, check: How to Update iPod to the Latest iOS Version
1helpful
How do I determine if I need to update my Kindle Fire?
Your Kindle Fire needs to be fully charged and connected to a Wi-Fi network before you can download the software update.
Tap the Quick Settings icon, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update.
How do I update my kindle?
Didn't update in time? Do a manual update At this point, you'll need to update your device manually. It'll require you to grab a USB cable and do the install with your Kindle connected a computer. Here's how:
  • Go to Amazon help page, find your device and click the link in the neighboring column to download the update. Use the above instruction to find out which software your device is currently running. In some cases, you might need to download and install more than one update.
  • Plug your Kindle into your computer. Once it appears as a drive, drag and drop the update file to your Kindle. (Not a subfolder, just the top-level Kindle drive.)
  • Eject your Kindle and disconnect the USB cord.
  • On your Kindle, go to Menu > Update your Kindle. Your Kindle will let you know when the update is complete.
abcFileHippo Download Free Latest Update Software and Printer Drivers
How to start an app that not loading at all
You should make sure that your iPad is running the latest firmware version. Also, make sure that your apps, especially the one you are having trouble with, is fully updated. These updates cover problems the software is having.
1. To check if your iPad firmware is up to date:
Go to "settings", then to "general" then to "software update".
2. To check on you apps update status, go to the "app store" icon,
then on the bottom, all the way to the right, there's an "updates" icon. The apps that have available updates are listed here. Make sure to update each out of date app.
Hope this fixes your problem!
Can't download IOS 6.0 to my IPad 2 .help
There are two ways to upgrade the iOS version of your iPad:
- via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
download-ios-6-0-ipad-2-help-idk31xyog1zytopaznkz4ivh-3-0.jpg download-ios-6-0-ipad-2-help-idk31xyog1zytopaznkz4ivh-3-2.jpg download-ios-6-0-ipad-2-help-idk31xyog1zytopaznkz4ivh-3-5.jpg
Download ios 7 update
There are two ways to update the iOS version of your iPad 2:
but only since iOS 5 it is possible to update the iOS version without the need to connect the iOS device to a computer (over-the-air update)
download-ios-7-update-hmu2cfrdaalq4nhfkdotj12h-4-2.jpg download-ios-7-update-hmu2cfrdaalq4nhfkdotj12h-4-8.jpg download-ios-7-update-hmu2cfrdaalq4nhfkdotj12h-4-12.jpg
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
