How to delete or move ALL emails at once in non-jail broken ipad or iphone
It took me weeks of research to figure out finally how to decode this yet another secretive secret of apple. There is a perfect way of deleting ALL emails at once without jailbreaking your iphone or ipad...and here it is:
>> Open Inbox >> Edit >> Mark All >> Mark As Read [Added May 21, 2014 by Adrian; this extra step makes the difference between success & failure for some.]
>> Open Inbox >> Edit >> Check/select the top message; it will highlight the move button.
>> Press and hold the move button and uncheck the message that you had checked earlier.
>> Lift all your fingers off from the ipad screen and leave it alone. Wait until all your messages pile up on the right hand portion of the screen (in ipad); iphone will give you the actual number of emails it has selected for the action. Now they are just waiting for your command to be moved ALL at once.
>> Choose trash to delete all of them or any other folder where u want to move them, like one piece. Remember this will replicate your action on the server so you will ACTUALLY move them or delete them on the server and not just the ipad.
Once you have moved all messages to the trash you can either leave them there for the scheduled cleaning or empty it right away by doing this: go to trash folder and touch Edit. The Delete All button shows up at the bottom of the screen. Hit it! You're done!
If you do not see the effects of your actions on the server make sure you have enabled your email accounts for such actions.
Tips:
1. Please give enough time (could take up to several minutes depending the number of emails to be moved) for the emails to be selected for the move. Your screen will become unresponsive while all emails are being packaged. Once emails are ready, in ipad, you will see them zoomed out on the right hand side of the screen, and in iphone you will see the message showing you the actual number of messages that have been selected.
2. Avoid purging very large number of emails, the mail app might freeze or crash. If your inbox has thousands of emails change your sync settings in mail settings to fill lesser number of emails in your inbox.
3. [Added Jul 20, 2014 by Adrian] Many people have reported needing to repeat the above procedure several times before it succeeds. (I too have found this to be necessary a few times on my iPhone but not on my iPad-go figure.) So my final tip is to repeat the procedure 3-4 times if the mail doesn't disappear the first time. In my experience, if your messages disappear momentarily and then reappear, repeating the procedure will eventually make them stay deleted for good.
4. [Added Sep 18, 2014 by Adrian] If you are using IOS 8, there is a setting that may reduce emails piling up on your device! Go to Settings -> Messages and select Keep Messages under the Message History header. You'll be able to choose to keep your messages for 30 Days, 1 Year, or Forever.
You will have to go into your trash folder (or rubbish bin depending on language preference) Click the edit button, select the emails that you want to delete and it will permenantly delete from your email account. Hope this helped!
Look for the Accounts section below your mailboxes (see image)
Select the account that you want to delete emails from. Select the folder (for example -Trash) Tap on this folder, and you will see the word "Edit" at the top right. Tap on Edit, select the emails that you want to delete (a blue check mark will appear to the left of each selection), and then look for the word "Delete" at the bottom right of the list of emails that you have selected. Tap on Delete and that should solve your problem.
As mariolands said, there is no trash bin because Apple wants to make the device as simple as possible for users to use. Actually, if you think about it, a trash/recycle bin is not even necessary as the user does not need to worry about things like that.
If you were wondering how to remove apps, then you have to hold any app icon on the home screen for several seconds until they start wiggling. As they begin to wiggle, you should see a cross in the top corner of each app. To delete an app, just tap on the "x" and it should be deleted.
As for the mail, once you're in the mail app, just swipe right on the message you want to delete and an option to delete will appear on the right. Alternatively, you can tap Edit at the top right and select the message(s) you want to delete.
Hope this helps,
-virjog
