Hello Monica, thank you for your post!
Based off the information you have provided your Electrolux washer is displaying an error code of “E40”. I am showing that an “E40” error code means this could be an issue with your door swicth or main control board. I would recommend performing a reset on your washer and you can do that by disconnecting the power cord for at least ten minutes. If you continue to receive the error code once power has been restored you may need to seek assistance from a professional technician for a proper diagnosis. Hopefully this information is helpful to you. –Matt
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
SOURCE: Washing Machine does not work and shows error code E40
E40 is a door related problem. Possible causes are faulty door interlock or door circuit triac on the main PCB.
Most likely cause is the door interlock.
SOURCE: E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit
behind the port hole door frame ,where the door
striker pin goes through hole.hope this helps you.held on with 2 screws
and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
SOURCE: electrolux ewf1074 error e40
I've just bought one of these machines, and the manual says the E40 warning means the door is not properly closed. Seems like that would be obvious if it were true, but maybe check that it is closing completely.
SOURCE: Electrolux front loading machine shows
E40: Door open, Interlock, wiring or main PCB failed.
