SOURCE: NEW DRUM
joe, to replace the drum, you need to remove the cover from the front of the drum unit it has three locking tabs,one removed,take main charger/grid unit out,located on the top of drum unit,two screws one on each end. the drum is held in with a cam lock shaft located on the front of the drum unit,turn it couter clockwise,your drum can now be removed,it's recomended that you replace the cleaning blade also,two scews. you'll have to coat the new drum with toner and manually turn it against the new cleanig blade,if you dont the blade may flip and ruin your new drum.reassemble
SOURCE: program mode
l have a error code H-2-00 on e studio 162d how should get into program mode to reset it?
SOURCE: error code H2-00 on e studio 162d?
u have a dirty thirmistor in fusr unit.first clean it.then do this procedure.press clear key,auto photo key,clear,auto photo key in a sequence.copier will go dead .when display goes dead just press 14 start key.copier will take few second and will bi ok.by MIAN AKHLAQ
SOURCE: Toshiba e-studio 162d makes smudgy black margin
Hello sir; you do need a drum blade to replace at least.
SOURCE: How do you reset Admin on a Toshiba e-studio 162D
In the manual it says to "Turn on power while holding down the status button on the network expansion kit. Continue to hold down the status button until a beep sounds."
It looks like the default password was TOSHIBA which took me forever to find. The user name should just be admin.
The e-STUDIO162 Series can do GDI printing out of the box. It can do PCL printing if the optional GA-1170 controller is installed. The GA-1170 is attached to the back of the MFP and connects to the USB port. Postscript printing is available if the Postscript option has been installed on the GA-1170.
Good luck
