Default 4 Digit user code: 1234,1122or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
The IMEI number is unique the each mobile/cell phone. The number is printed on the label under the battery. You can also get the IMEI number by entering this on your phone *#06# It will then display your IMEI number and you may also get a unique global serial number. Your IMEI number should be 15 digits.
Hi, - To unlock you Nokia N900 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password. - The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
