SOURCE: error message 50 and 30
see here: http://www.fixya.com/support/t211210-brother_mfc845cw In case this is a new printer give it back to the dealer. Its in guarantee.
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
SOURCE: print want print
If you recently purchased it, just put it back in the box and take it back to the store for a replacement. I wouldn't bother tryng to fix it if you can get a brand new one that works the way it's supposed to.
SOURCE: unabe to print 36 message when trying to print web pages
To fix the problem, remove the back cover and raise the top lid where you change the printer cartridge. Once back cover is removed, there is a small plastic tab that you need to press down with one finger. With the other finger, press the tab underneath the top cover (in front of the stop button). Both of these tabs are safety features that have to be pushed down together to make the printer head move from one side of the printer to the other. When the printer head moves, you should see the paper lodged underneath or behind the printer head. Remove paper, replace back cover and lid. The printer should go through a printer mode and work normally.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
