Machine has been stored for 2 years un-used. rest of cycle appears fine.
SOURCE: Smoke in drum on spin cycle
I did it by going to an agent, I do not trust you,,,how do I know that your services are for real? Please do not be offended.
SOURCE: Miele W3725 - normally i
I dont think there is any link that after you used the soft cycle a fault had crept in.
In fact the fault appears more as a program controller working erratic.
hence I would like you to clean the inlet valve filters, the outlet drain filters, check all the connections to the program controller unit and finally making sure that there is no loose connection at the supply point.
Tighten all connectiions , check the door switch - clean and reset as a faulty intermittent connection can make it reset the program.
What is the model number of your unit?
