Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site...
SOURCE: Horizontal line on TV screen. Has sound but no picture
Your vertical IC has most likely failed
SOURCE: tv not showing picture but just horizontal line.
Failure of vertical output. Check vertical output components.
SOURCE: Hi there My Sansui TV screen
It is an indication that you have a problem on the vertical section on the main board.
The faulty parts is the electrolytic capacitor which affect the linearity of the screen that's why you encountered that kind of problem.
I've advice you to send it to repair shop or look for a qualified technician to isolate the faulty electrolytic capacitor and do re-soldering for some dry joints on the main board.Once replaced the capacitor your unit will back to normal again.
thanks for using fixya...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
SOURCE: have a sylvania srt 2027 27 inch tv horizontal line no picture but have sound
The vertical scan output section circuit is faulty. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
