Question about Bulova Watch
Can you date this watch serial # 7779193
I would like to know how old my watch is
I have a mans accutron bulova watch serial number H 963884 look for info year value
Value information here
https://www.google.ca/search?rls=com.microsoft:en-CA:IE-ContextMenu&biw=1438&bih=677&q=bulova+accutron+serial+numbers&sa=X&sqi=2&ved=0ahUKEwjM14mTz7PQAhUT4mMKHb7LB3YQ1QIIZCgB
Determining the Date of a Bulova Watch For purposes of assigning a date, Bulova watches break down nicely into three basic groups: 1) pre-1926, 2) 1926 through 1949, and 3) 1950 and beyond. Those three date ranges are differentiated by the presence or absence of certain case and movement markings as well as the nature of any such markings, as explained below.
In general, for all time periods, it is important to understand that Bulova watches never provide an obvious date of manufacture anywhere on the watch. Rather, the date must be "de-coded" using symbols, serial numbers, and two-character codes placed on various parts of the watch. These codes and the manner in which they should be interpreted is the subject of this article.
Many observers of Bulova watches are confused by the sometimes seen patent dates stamped on the inside of some Bulova watch cases, and they misinterpret such dates as the time of manufacture. In point of fact, those patent dates apply only to certain aspects of the case design and indicate only when those general designs were patented. Those designs were used on many watches produced over a number of years, and the applicable patent date in no way indicates when any particular watch was produced. Below are images showing the two patent dates that often cause confusion.
Read LOTS more HERE: http://www.watchophilia.com/general-information/determining-the-date-of-a-watch/
accutron bulova Google Search
Nov 19, 2016 | Bulova Watches
How to set the time and date to my rolex, and if under number 6 when you remove bracelet i don't have number that means is a fake?
That number does correspond with a genuine Rolex. Stop Ina watch repair store where they actually do the work. I have not seen a knock off with a serial numbers or model number stamped between the case lugs.
Hope this helps.
Nov 11, 2014 | Rolex Oyster Perpetual Lady Datejust...
Whats the value of bulova watch c9671206 ?
NEED MORE INFO. From that serial number, it might be one of the old tuning fork movement watches. If the date code is from M0 (1960) through N6 (1977) it likely is. If so, it has a collector's value. In any case, the exact model, type of movement, and year would be needed to come up with a value. The serial number is just not enough.
Jul 26, 2014 | Bulova Diamond Watches
Need help identifying watch
Take it to a local jeweler and they will tell you all about it for free.
Search Results
How to tell when your Seiko watch was made (Part 1)
quartzimodo.com/how-to-tell-when-your-seiko-watch-was-made-part-1/ Sep 21, 2010 - If you can't see the serial number on the glass, then look for them on the caseback ... Every Seiko watch manufactured is given a 6-digit serial number. ...... Your old Seiko watch is likely to be from the Seiko Sportsmatic or the ...
WatchSleuth - Seiko Date Finder
www.watchsleuth.com/seikodatefinder/ Seiko Date Finder - Find out when your Seiko watch was made. ... In the example images the serial number is highlighted in blue. Every watch has a unique combination of reference ... the watch was made. Looking at the example images:.
Watch Finder ' Seiko
www.seiko.com.au/collections/seiko-watch-finder Watch Finder. Seiko Watch Finder ยท Seiko Clock Finder. Search by Model Number. Collection. - Any -, Grand Seiko, Astron, Prospex Platinum, Prospex, Presage
images below
older seiko watch with dubai australia chicago on bezel Google Search
Jul 31, 2017 | Seiko Watches
I have a citizen elegance water resistant watch with serial number 891188. I need 2 links added onto it for it to fit me.
My watch is an Elegance that is thirty years old with sentimental value. I don't know how old your watch is or how much you want to put into it. I would contact Citizen to see if they could fix you up with something if you haven't done so already. They should have these watches cataloged. You may have to send it back to them.
Jan 03, 2013 | Citizen Watches Citizen Elegance Signature...
Hello please help, I wish to know what year Rolex Oyster Perpetual Lady Date model 6519 was Manufactured. Thank you in advance.
This model Rolex has been manufactured over multiple years, and it is not possible to date your watch based purely on is model number. However, it is possible to date most Rolexes based on their serial numbers, which can be found stamped between the lower lugs (i.e., the lugs below 6:00 on the watch dial). You will need to remove the band from these lugs to read the serial number.
Dating the watch case of a Rolex does not necessarily date the entire watch. It is possible that a movement from another watch was placed into a watch case that is younger or older than the the movement. Like Rolex watch cases, Rolex movements can also be dated by their serial numbers, if this is a concern you have about this particular watch.
This jeweler has put together a nice summary of when Rolex watch models were introduced and which serial numbers are associated with specific years of manufacture. Once you have found your serial number, this should help you date your watch. I have no connection (financial or otherwise) with this web site, but I found the information useful and presented in an easy to understand way.
http://www.bgrayjewelers.com/rolex_information.htm
Jun 03, 2011 | Watches
Just bought a vintage Citizen Super Crystal Date stainless steel watch. Serial No. on back is 00625090. Can you provide the approximate or exact date of production? Thank you.
We cannot tell you from the serial number what the model watch you bought is . But you can call Citizen watch 800 321 1023 extension 4234 and give them the serial and they will be able to tell you the model and year the watch was produced.
Oct 14, 2010 | Watches
I have a fairly old jack daniels pocket watch and i cant seem to find any info on it...value.. manufacturer etc ..I do have a serial number 3780 G
I gave my husband one like you describe when we were dating (1985) that I bought from a antique store dealer. While I knew this wasn't an antique, I still would like info on it. I've called the distillery office, left msgs, and never gotten a response. Ours is serial # 2032G. Would love to have some info.
Feb 21, 2010 | Watches
Need to know date of movado watch by serial #s on back. 87-A2-864 then underneath 1624076 watch has white face , gold dot and hands, gold case, leather strap
Go to Modavo.com and on the opening page you will see "service" in the menu.
Select this and then "other questions................" and ask them.
Jan 31, 2010 | Watches
Bulova Watch Logo
101 people viewed this question
Top Bulova Watches Experts
Janelle Schoonover
Janelle Schoonover
Anthony Ward
Anthony Ward
Chan Sun
Are you a Bulova Watch Expert? Answer questions, earn points and help others
