SOURCE: I have a springfiel savage 22 model 234 bolt
Numrich has them for $20.55 for a ten round mag. They have a five round also, but they're sold out.
http://www.gunpartscorp.com/catalog/Search.aspx?catid=0&filter=115610C
SOURCE: what year was this savage model 99 lever action
Regards,
Tony
SOURCE: How to determine the model and serial number of a marlin 22 rifle?
this is copied from a site, the web address is pasted below.
The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
also if you find serial # you may find more info here.
http://oldguns.net/sn_php/marlinlookup.php
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
SOURCE: What year is my model 110 savage arms rifle serial number F313037?
here is a bit of history on your rifle.
Savage Model 110
savage has changed a lot, I went to there web site, looked under customer service, then under look up date of manufacture & typed in your serial #, the only info that i got was that they said that they didn't service models before serial # f498821. here is the link.
http://www.savagearms.com/firearms/models/
