SOURCE: GOODMAN MODEL CKJ30-1A
I think you mean compressor rather than condenser. Take the panel that covers the controls off the unit. If the clicking noise is the contacter, and it is engaging when the power is turned on, then follow the wires to the compressor, remove the little plastic cover and look for wires that are burnt or otherwise not making contact with the compressor terminals. If the wires are good and you have a volt meter, set it to ohms, TURN OFF THE POWER, remove the wires on the compressor. (remember where C,S,R, goes) touch the meter to any 2 terminals on the compressor. They all 3 should have continuity to each other. No continuity=new compressor. If the contacter is not making the clicking noise when the power is turned on, then you have another problem that I'll need more info. to help.
SOURCE: goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
SOURCE: How do I turn on
If it is the breaker box in your house, then just push it to the side so it is lined up with the other breakers in the box. Actually any breaker will be like that. If it is the disconnect outside then it pulls out and you flip it over and put it back in.
SOURCE: My goodman central air unit
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck.
