How to fix the error codes in hp 5550 dtn laser jet?
Here is the HP Laptop Technical Support Number 1-844-355-5111 (toll-free) to fix hp 5550 error code by expert technicians.
HP Laptop Support Number 1 844 355 5111 Laptop Repair
To fix hp5550 error code here is HP Customer support Phone Number 1-800-281-3707 to give you quick solution 24*7.Here you get support from experts. HP Customer Support Phone Number 1 8002813707Help
It has been a while but I think it can be fixed by replacing the chip on the cartridge. A local cartridge refiller could probably replace it for a small fee.
SOURCE: error 13.10 paer jam in HP laser jet 5100 DTN
HI ayyasamyr:
This your problem.
13.10 PAPER JAM The event log message for a paper-delay jam in the duplexer is 13.10.
1. Check the duplexer and the rear area of the printer for obstructions or damage.
2. Check PS1701 and PS1703 in the duplexer for correct operation. Replace the
duplexer if a sensor is defective.
Hope this helps
SOURCE: Error 49 4CO2 Service Error on a HP Laser Jet
This is related to the JetDirect Card and the specific print job attempting to print. If JetDirect is 615 or lower slide out JetDirect card and power cycle printer once it comes up o.k power down and
slide JetDirect card back in once the printer is back up look on the display for processing job which may take 5 minutes but it is the offending job trying to print again as it is still in the print que. If you are quick enough you can hit cancel on the display panel to cancel the corrupt printjob and if you are successful then the other print jobs stacked behind it should start printing away with no problem. Hp blames the 49 error on a plethora of problems though mine are usually related to documents using different versions of Adobe and also PowerPoint printjobs that are excessively large as the print spooler cannot handle them but it is always a corrupt print job and once that is cleared no problem. Occasionaly replacing the JetDirect card is required to solve the issue. With the 620 Jetdirect card no need to remove it just unplug the network cable same procedure as above.
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Testimonial: "It worked. Thanks. I' just FIXYA again"
SOURCE: HP 5550 dtn service code
The 59 error code means that there is a problem with the printer motor. Sometimes this coincides with an problem with the ETB (electrostatic transport) message. If the ETB message is there, check that it is properly installed or replace it. It is also called the Image Transfer Unit, c9734a.
Otherwise, press the Select button (green with the check mark) then turn the printer off and on. Check if the message persists. If it does, then try a cold reset of the unit. Watch the printer control panel closely during the reset procedure. Turn on the printer and press and hold Select when you see the memory start counting. Hold the Select button until the lights (Ready, Data, and Attention) flash once and then become steady. Release the Select button when the lights are steady. The Control Panel will read Select Language. Press the Down arrow once and the display will read Cold Reset. Press Select. The cold reset will be preformed and then the usual startup will resume. If the message persists, the unit needs service.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=409994&prodTypeId=18972&prodSeriesId=409994&objectID=bpl12227#A60 has details on the 59 error code. For more information on the ETB kit, see http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00004080&prodTypeId=18972&prodSeriesId=409994 . There is a flag attached to the ETB that sometimes comes loose and can be reseated to correct the problem. If it breaks, you need to replace the ETB.
I hope this helps.
SOURCE: on power up of HP5550
I'll list what the book says, but if you haven't got the basic knowledge
you are going to have to call a printer tech. Good luck
1.
Press CANCEL JOB to clear the
print job from the printer
memory.
2.
Turn the printer off and then
back on.
3.
Try printing a job from a
different software application.
If the job prints, go back to
the first application and try
printing a different file. If the
message appears only with a
certain software application or
print job, contact the software
vendor for assistance.
4.
If the message persists with
different software applications
and print jobs, disconnect all
cables to the printer that
connect it to the network or
PC.
5.
Turn the printer off.
6.
Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
7.
Remove all EIO devices from
the printer.
8.
Turn the printer on.
9.
If the error no longer exists,
install each DIMM and EIO
device one at a time, making
sure to turn the printer off and
back on as you install each
device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
cables that connect the
printer to the network or
computer.
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter
