NEC Dterm 80 Phone Dth-8d-1 bk Tel 780571 780071 Professionally Refurbished Logo
Mary Jean Barry Posted on Apr 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When calling voicemail I receive a message after entering my access code that states "I'm sorry, I can't talk to you right now"
How can I get this to go away and check my messages?
Brian LaDuca
Level 2:
  • Expert 149 Answers
  • Posted on Mar 07, 2017
 Brian LaDuca
Expert
Level 2:
Answers
149
Questions
0
Helped
146614
Points
228
This means the voicemail card is full. look at all extensions mailboxes or a general message mailbox and delete all the messages and try again. If it is no good still you will need to get in the admin mailbox and change your mailbox to allow messages.
1helpful
2answers
Why am I not receiving General Mailbox voicemails?
Please make sure that the customer is calling the correct number that you think that they're calling. Then, call this number yourself and leave a message before going to check the message again. If you can't find your message, please call the business' phone company and ask them if there are multiple mailboxes linked to your business phone number. If so, they can provide access to the other mailbox for you.
Thank you.
1helpful
How do I access my voicemail from another phone?
To call your Voice Mail from a landline phone:
1. Call your TracFone from a landline phone.
2. When your voicemail begins, press the star key on your landline phone immediately.
3. Enter the PIN you use to check your Voice Mail from your TracFone. When you have finished entering your PIN, press the pound key.
4. Listen to the instructions. They will tell you how many voicemail messages you have and give you options for checking them, deleting them, saving them or storing them as new messages. Phones may vary, so listen carefully to the options.
if you havent created a pass code try 9999, if that doesnt work give tracfone a call.
1-800-867-7183
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 • Cell Phones
15helpful
4answers
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
12helpful
2answers
New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
93helpful
5answers
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • 0helpful
    2answers
    Cannot access voicemail on Motorola Razr
    If your wife never reset the codes when she used the phone, the "unlock" 4 digit PIN code is usually 1234, or sometimes the service provider resets it to the last 4 digits of your cell phone's number before sending it to you.
    The SECURITY code is a 6 digit code which is set to "000000" when the phone is first sent to you and since your wife never used it that should still be it. I'd try entering 000000 for the "invalid security code" message you are getting and see if that does it. Some service providers may reset that security code before sending the phone to you too, so if any of those codes don't work you'll have to call your cell phone service provider to find out the codes. This info about all the codes was in my Razr V3 manual. Hope it helps.  If that does work for you and you can get into voicemail, then to reset the codes to your own personal ones go to ....Settings > Security > New Passwords and reset them.
    If you get to the voicemail message screen and the message  stored there, (it's probably a message from the service provider) you have to call the voicemail number to retrieve the message, I just  press the keypad "dot" on the top right side under where it will say "call " and it dials & brings me to my voicemail.  The voicemail number should be stored in the phone, but because it was never set up you may have to call the provider to do so, I can't remember if it was already in there or not when I first set my phone up. Anyways......Good Luck & Happy New Year ; )
    Receive error message in Voicemail.
    Voice mail is full need to delete a few messages.
    Top NEC Lands Phones Experts
    ADMIN Andrew
    ADMIN Andrew
    Don A
    Don A
    RAJA NADEEM AKHTER
    RAJA NADEEM AKHTER
    Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
