Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
SOURCE: washing machine moter
green is ground, white is neutral, red/black is usually hot on a 1 phase 110-120v motor. (normal colors are black, white, green).
if three phase, (208-220v), green is ground, white, is neutral, black/red/blue are hot. (only uses 2 of these, so there should only be a total of 4 wires). once you have the wiring connected, turn on the motor, and check the rotation direction it turns. if it turns backwards, reverse the red/black wires, the red/white wires, or the black/white wires.
be sure you look at the data plate on the motor to determine one or three phase motor.
their should be a small diagram of which wire inside go to which other wires inside on a three phase motor and for which voltage, and are usually numbered on the individual wire.
good luck.
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
SOURCE: A washing machine Electrolux EWF 1025 does not start up.
E50 is displayed if the there is no drum rotation. drum jammed not allowing motor to turn/ no circuit through motor(poss worn out carbon brushes) less likeley but poss short on motor relay on electronic board.
